Old 08-22-2016, 09:54 AM   #1
Global Nomad
Scheinin's Avatar
Hot H20 pressure kitchen
I have a 36CKTS 2016 Cedar Creek with instant hot water. My hot water pressure in kitchen has dropped. Cold water pressure is fine in kitchen. Hot water pressure fine in bathroom sink and shower. Only in kitchen. This low pressure prevents instant hot water heater from turning on. Any suggestions as to why after 6 month reduced pressure in kitchen only?
Steven J. Scheinin
2015 RAM 3500 4X4
6.7L CTD Dually pulling a
2016 Cedar Creek 36CKTS
Scheinin is offline   Reply With Quote
Old 08-22-2016, 10:17 AM   #2
Probably some debris in the hot side cartridge of the kitchen faucet.
Pull it apart and check.
A line could also have been partially kinked and has now completely closed off too.
Not a common problem but more so on the hot side as the hot water makes the hose/line more flexible and kinks more easily.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 08-22-2016, 09:47 PM   #3
Global Nomad
Scheinin's Avatar
[QUOTE=5picker;1296761]Probably some debris in the hot side cartridge of the kitchen faucet.
I am not sure what you mean by "cartridge" I traced the hot water line, as best I can, from intake to spicket with no hinderance. I suspect the problem is between intake and instant hot water heater.
Steven J. Scheinin
2015 RAM 3500 4X4
Old 08-22-2016, 11:04 PM   #4
If you hot pressure is good everywhere but the kitchen, then it is most likely in the hot cartridge under the hot handle if two handle or if single handle faucet, in the hot inlet of the mixing Cartridge under that handle is what 5 picker was saying. If the cartridge is clean it could be in the tee going up to the faucet. I am assuming that cold is good at the kitchen and hot and cold are good everywhere else.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
Old 08-23-2016, 05:08 AM   #5
ilmor's Avatar
Maybe a hot water tube / pipe got pinched somewhere / somehow?
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 08-23-2016, 09:07 AM   #6
The cartridge is the part in the faucet (inside, under the handle) that controls the water flow to the spigot when turning the handle.
Often times, debris (sediment, shavings, etc.) can lodge inside the cartridge and plug it up and water will not flow.
(or flows very slowly)
You will need to disassemble the faucet to see if that is the problem. Usually if plugged and not leaking, they can simply be cleaned, rather than replaced.
Old 08-24-2016, 01:44 AM   #7
Global Nomad
Scheinin's Avatar
faucet and connections
[QUOTE=5picker;1297760]The cartridge is the part in the faucet (inside, under the handle) that controls the water flow to the spigot when turning the handle.
Thank you. Attached is a photo of my single handle faucet and the connections under the sink. The hot and cold water lines each go into a copper (?) pipe that goes into the faucet. I dread taking this apart.
Name:	scheinin faucet_Fotor.jpg
ID:	118266   Click image for larger version
Name:	scheinin connection_Fotor.jpg
Steven J. Scheinin
2015 RAM 3500 4X4
Old 08-24-2016, 08:20 AM   #8
Herk7769's Avatar
This can be prevented in the future by never draining your hot water tank through the low point drains.
If you use the low point drain to drain the hot water tank, debris from bits of anode and calcium nuggets get pulled into the cold water lines during drainage (the cold water feed is at the bottom of the tank). ALWAYS close the winterization valves on the back of the water heater and use the anode plug to drain the hot water heater.
If you suck that crud into the cold water pipes, it can stay in the fittings and low spots until you re-pressurize with anti-freeze, water, or air pressure. Then it will make its way to your valves and toilet flush valve causing all sorts of bad (and sometimes expensive) problems.
ID:	118296   Click image for larger version
ID:	118297   Click image for larger version
ID:	118298   Click image for larger version
ID:	118299   Click image for larger version
Name:	Camper Bidet 022.jpg
Name:	Camper Bidet 025.jpg
HAM CALLSIGN - KC3FFW
Old 08-24-2016, 08:24 AM   #9
Herk7769's Avatar
[QUOTE=Scheinin;1298603]
If they did not give you the installation manual for that faucet as part of your package, I would call the parts department of your dealer or Cedar Creek and with your VIN, ask for the manufacturer of the sink faucet.
Then you can get the disassembly instructions and order a repair kit if needed.
Here is something close that came off the internet. There may even be a YouTube video if you have the correct make and model faucet.
Old 08-24-2016, 10:03 AM   #10
Global Nomad
Scheinin's Avatar
[QUOTE=Herk7769;1298694]This can be prevented in the future by never draining your hot water tank through the low point drains.
Thank you. I am full timing and therefore don't winterize. I have never drained hot water tank as I have instant hot water.
Steven J. Scheinin
2015 RAM 3500 4X4
pressure
