Old 04-22-2018, 09:53 AM   #1
Hot water
When we open the camper this year and turn the water heater on our hot water only stays hot for about a minute then turns back to cold. Can someone help me with this are we doing something wrong. We own a 2016 vibe
Rosie314 is offline   Reply With Quote
Old 04-22-2018, 09:55 AM   #2
Do you have all the taps turned off? Sometimes that will mess up the temperatures.
hrhsharonnick is offline   Reply With Quote
Old 04-22-2018, 09:57 AM   #3
Oaklevel's Avatar
Also check to see that all of the water heater bypass valves are in the correct position.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 04-22-2018, 10:01 AM   #4
This is our first year doing this and we are not sure which position they should be in. How can I find out the right position
Old 04-22-2018, 10:07 AM   #5
Heating element on water heater
Can someone tell me where the heating element on the water heater is only 2016 vibe
Old 04-22-2018, 10:10 AM   #6
The shutoff values are easy. If the tap goes across the line itís closed. If itís with the line itís open. Basically the lines going into and out of the heater need to be in line and the one going between the 2 lines , the bypass line, needs to be across the line.
Old 04-22-2018, 10:15 AM   #7
wmtire's Avatar
This thread that we keep as a sticky at the top of the plumbing section may help, as it explains the bypass/crossover valves for winterization.
NO (OR LUKEWARM) HOT WATER -Please read first
2011 Flagstaff 831 RLBSS
Words are powerful.
Choose them good.
Old 04-22-2018, 11:05 AM   #8
Got water
Thanks everyone for your help we now have hot water, We had one of the valves turned the wrong way thanks again
hot water, water
