Old 10-25-2018, 02:49 PM   #1
Hot Water
Just noticed when taking shower that hot water seems to be running out. Never happened before. Connected to power. Could this be thermostat or element?? Water is hot but just not lasting thru shower. Thanks in advance for your help!!!
Cardinal camper is offline   Reply With Quote
Old 10-25-2018, 03:41 PM   #2
BuzzWolfAR's Avatar
If you are using an electric water heater, the anode may be worn out.
Buzz & Jo Wolf
5er: 2018 Cedar Creek 29ik
TV: 2014 F350 Diesel
BuzzWolfAR is offline   Reply With Quote
Old 10-25-2018, 03:51 PM   #3
bikendan's Avatar
You mean heating element, not anode rod.
The anode has nothing to do with heating the water.
Equalizer WDH
Old 10-25-2018, 04:15 PM   #4
wmtire's Avatar
Is you water heater a tank type or tankless
If tank type, is it propane and also has an electric heating element.
Are you using propane and electric, or just one heating method?
Brand and model would help too.
Have you messed with any of the winterization valves....or the outdoor shower recently
NO (OR LUKEWARM) HOT WATER -Please read first
2011 Flagstaff 831 RLBSS
As I've told my kids a hundred zillion times, "Don't exaggerate."
Old 10-25-2018, 05:53 PM   #5
TimVWulp's Avatar
where are you located? is the weather getting colder which may cool the in coming water temperature to the water heater. This will cause water heater not to keep up as it takes more BTU/watts for the electric element to warm the water that is being used.
Not sure if this is your problem as there is not enough information Tim
TimVWulp is online now   Reply With Quote
Old 10-25-2018, 07:08 PM   #6
South Carolina. Not very cold yet. Never had this situation before. Thought maybe the element could be going out, causing the water not to be heated as quick as it should.
Old 10-25-2018, 07:46 PM   #7
TimVWulp's Avatar
Forest River Forums - Downloads - WH_Service and Training Manual 05-18-11.pdf
The above link is from the Library at the top of the page. You will need to download it and open it at the bottom of the screen. On page 18 _ 19 is trouble shooting for the water heater electric side. The one scenario that jumped out at me was that the heating element may be encrusted with calcium from hard water. This will insulate the heating element slowing down the heat transfer to the water. If the hot water heater is full of calcium go the store and buy a gallon of vinegar remove the pressure releaf valve and put the vinegar in the hot water heater tank. fill to top with vinegar and water let it sit for an hour and flush the heater with water to remove the vinegar. leave the releaf valve out to vent the calcium carbonate gas that is created from dissolving the calcium. Just a stab in the dark.
hope this helps Tim
hot water, water
