Old 09-22-2013, 07:37 PM   #11
Ford Idaho's Avatar
I am gonna guess he turned the water heater on with little or no water inside.
Heater element may be fried.
Old 09-22-2013, 07:40 PM   #12
davel3083's Avatar
No, still having same problem, I know enough to be sure there is water in the hot water tank
Before starting the pilot light and turning it on, hot water at the tank, it's just not traveling thru all the lines for some reason.
davel3083 is offline   Reply With Quote
Old 09-22-2013, 09:16 PM   #13
Denver, CO
garbonz's Avatar
Has ther EVER been hot water? soind to mr like a plumbing problem, so find the closest hot water spigot to the tank, and if that is warm there may be misrouted plumbing. or if this has just happened it might be a control board or thermal sensor that is signaling the burner/heating element to shut of.
One thing to try carefully is heat the water to shut off and then turn off the HW heater, release the pressure in the lines (pump off and no water pressure), and then with gloves carefully unscrew the anode, and see if THAT water is hot. If it is it most certainly is the bypass or something else in the water lines, if it is only warm, it is the water heater. Be carefull and don't get scalded. make sure all pressure is off, and ALL the power and gas is shut off. AND then be real careful... and even more careful.
2017 Fuse 23T
Old 09-22-2013, 09:23 PM   #14
davel3083 - Did you check your valves at the tank? Cold in, the hot out open and the bypass closed? Check the bypass valve to make sure that the handle position and valve position make sense (don't assume)...
Camped: 2017 (Days/Nights) - 30/25
2016 (Days/Nights) - 32/23, 2015 Nights - 29
TT: 2013 26' Revere TBQB
TV: 2014 GMC Sierra 1500 Z71 4x4
glen1971 is offline   Reply With Quote
Old 09-22-2013, 09:33 PM   #15
VinceU's Avatar
Another possibility- at the hot outlet, there sould be a non return valve. Prevents water backflow into heater, completes design of 3 way valve.
Old 09-22-2013, 09:39 PM   #16
jimh's Avatar
check and see if u have both hot and cold valves open (at one of the faucets) and shut off at the shower head. an external shower can do this.
jimh is offline   Reply With Quote
Old 09-22-2013, 10:49 PM   #17
BillyBass's Avatar
Originally Posted by davel3083 View Post
So I need to turn it to off position to get hot water ?vv
no you need to turn it on the other position it is off.Do you have a filter on it
2012 21' FR Micro Lite FBRS
2005 GMC Sierra 1500
2012 24 nites 2016 16 nites
2013 25 nites 2017 19 nites
2014 14 nites
2015 16 nites
BillyBass is offline   Reply With Quote
