Old 07-02-2015, 02:21 PM   #11
BobHanke's Avatar
Please note in the picture above that when the electric element switch is up it is OFF.
BobHanke is offline   Reply With Quote
Old 07-02-2015, 02:32 PM   #12
Boss Ox & Drovergirl
oxcamper's Avatar
Campers DIE for more hot water. I'd sell it.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 07-02-2015, 05:28 PM   #13
If water heater comes on with inside switch off check switch and wiring. You can also pull the water heater fuse to verify.
Harkerr is offline   Reply With Quote
Old 07-02-2015, 07:33 PM   #14
Hot water all the time
The switch inside on the panel is off. We are in the middle of a forest so no hookups. The switch outside is on....should it be off?
kanderson is offline   Reply With Quote
Old 07-02-2015, 08:48 PM   #15
BobHanke's Avatar
When switch outside is on, 110V AC is going to the electrical heating element. It will heat the water when it is on (and burn out if you turn it on without water in the heater). Turn off if you do not need/want hot water. The heater tank will hold heat for quite awhile when not drawing off of it.
Old 07-02-2015, 09:41 PM   #16
Try turning the outside switch off as well
Old 07-02-2015, 09:53 PM   #17
Batts-toy's Avatar
I keep it off unless I specificly want hot water from it, this way it doesn't get forgotten. You indicated being in the woods with no hookups, If you are running a generator feeding power to your unit then you are heating the water with 110v when the outside switch is on.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 07-03-2015, 11:38 AM   #18
Well, "on" means on and "off" means off so if you want the water heater off the switch should be "off" and if you want the water heater on you should switch it to "on".
The inside panel switch is for propane and the switch outside is for electric.
Do you want the water heater off? Switch it to off.
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is offline   Reply With Quote
Old 07-03-2015, 11:50 AM   #19
Mr. Dan's Avatar
Are you running a generator?
What are you doing for electricity - since you say you have no hookups?
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 7; booked = 22
hot water, water
