Old 10-20-2015, 05:55 PM   #1
keeprr's Avatar
Hot Water By Pass Valves
I have a Mini Lite 2502KS and am not sure of valve positions should be in winterized mode. What is the correct valvewinterize positions in winterized mode?
Currently (summer position) the valve on the hot side is open. The valve on the cold side is open. The valve between hot and cold is closed.
I will be blowing out the water system (no antifreeze except for the drains).
Thank you for your help.
2016 Open Range Light 297RLS Fifth Wheel
2015 GMC 2500HD 6.6L Duramax
Days Camped. 2015: 17
Days Camped 2016: 58
keeprr is offline   Reply With Quote
Old 10-21-2015, 10:32 AM   #2
If you're not using antifreeze, then you shouldn't need to fiddle with the valves at all. The valves are there to prevent antifreeze from entering the water heater. Just make sure that you drain the water heater ---- blow it our well.
bruceatlam is offline   Reply With Quote
Old 10-21-2015, 10:45 AM   #3
The correct position for the valve to be in bypass are:
Hot side-closed. Cold side-closed. Valve in between-open.
This configuration allows the piping to 'bypass' the WH and keeps liquid from entering.
you mentioned blowing out the system. Make sure you remove the WH drain plug (or anode rod) to remove the water from inside the tank.
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 10-21-2015, 12:49 PM   #4
Name:   Summer Position.jpg
Name:   Winter Position.jpg
Old 10-21-2015, 01:14 PM   #5
Who Dares, Wins
doc73's Avatar
Man those pictures have been getting a work out this week! LOL
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 10-21-2015, 01:32 PM   #6
TURBS's Avatar
And an oddly familiar wh heater I might add!
TURBS
2008 duramax
2015 columbus 320RS
2015 camping "31 nights"
Old 10-21-2015, 01:51 PM   #7
fonzie's Avatar
TURBS
2008 duramax
2015 columbus 320RS
and why re-invent the wheel when we have yours......
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 10-21-2015, 01:56 PM   #8
TURBS's Avatar
Lol
Actually it's somebody else's wheel now!
TURBS
2008 duramax
2015 columbus 320RS
Old 10-21-2015, 03:45 PM   #9
keeprr's Avatar
Thanks everyone. I appreciate the help.
Old 10-22-2015, 05:47 PM   #10
Wrong on everything. You can't drain the hw heater unless you switch the valves unless you are trying to drain everything.
Winter bypass on your system is easy, just reverse each of the three valves. Then you can drain the hw heater tank. By switching the valves you can now use your water system without adding water to the hw heater tank.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
hot water, water, valve
