Old 05-11-2015, 07:50 AM   #1
Hot water bypass
What is the purpose of hot water bypass?
Arkguy29 is offline   Reply With Quote
Old 05-11-2015, 07:52 AM   #2
No need to fill the hot water heater with antifreeze when winterizing.
Old 05-11-2015, 07:56 AM   #3
Campster's Avatar
It let you bypass or take the water heater out of the loop when winterizing your trailer. You bypass the water heater before filling the plumbing with antifreeze. That way you don't have to use six gallons worth of antifreeze to fill the tank before it goes through the rest of the plumbing.....
Campster is offline   Reply With Quote
Old 05-11-2015, 08:01 AM   #4
Flybob's Avatar
The water heater bypass is used to remove the water heater from the system when winterizing. If the WH is drained via the drain plug or anode rod, it does not require the addition of antifreeze. Without the WH in the system, winterizing requires between 3/4 gal and 2 gals of antifreeze ( depending on model / size of RV. With the WH in the system, between 7 and 9 gals of antifreeze would be required. It would also be more effort to clear the system in the spring. Most RV's have a bypass. If the RV has been winterized it is critical that the bypass be switched to normal use prior to firing up the WH ( either electric or propane) or the WH can be damaged.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-11-2015, 09:18 AM   #5
Old 05-11-2015, 09:27 AM   #6
Also you can use bypass if there is a (Problem) with W/H and Keep on Camping! Youroo!!
bypass, hot water, water
