The bottom picture is correct for normal use.
The upper picture is not correct for any use.
Go by the diagrams fonzie posted, they show the correct position for the valves.
explaination:
When the middle valve is shut, water goes in from the cold (blue) hose through the heater and out through the hot (red) hose. The middle valve prevents the cold water from bypassing the hot water tank. If left on, it will add cold water to your hot water.
When the middle valve is open and the cold and hot (blue and red) valves are shut, the water heater is isolated from any water getting to it and you will only have cold water. This is the position for winterizing, as you do not want antifreeze in your hot water heater.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2016 GMC 3500HD Duramax dually
1992 Goldwing Aspencade
