Old 12-25-2015, 06:36 AM   #1
Hot Water bypass
Where would the hot water bypass be in my unit (see signature line)? Since I had it winterized at a dealership I have not had the opportunity to work with the bypass but I will need to when I get down south and de-winterize. I'm pretty clear on the process - just don't know where the bypass is located.
All help appreciated.
Thanks.
2016 Rockwood Signature Ultra Lite 8329SS
2004 Dodge Ram 3500 (Sterling) Auto w/built trans, 4X4 Quad Cab 5.9L Cummins
mikemc53 is offline   Reply With Quote
Old 12-25-2015, 06:42 AM   #2
On the back of the hot water heater.
beachcamper is offline   Reply With Quote
Old 12-25-2015, 06:45 AM   #3
Platokidd's Avatar
My guess from looking your unit up online;
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Platokidd is online now   Reply With Quote
Old 12-25-2015, 06:48 AM   #4
PhoneDude 8289's Avatar
Behind the water heater. Three valves, cold going into the heater, hot coming out and bypass valve between them. In bypass mode cold and hot are off and bypass between them open. reverse the three to put the heater back into service. Be sure the water heater is full of water before restoring electric power, a nano second of power to the heating element without water in the tank will destroy the element. You should have access to the rear of the water heater by removing a panel or drawer or something like that.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 12-25-2015, 06:52 AM   #5
By your layout I have a WAG that your W/H bypass is located Inside a Kit Base Cab,might have to Pull and Remove sliding Drawer to gain acess,and have Long Arms! Youroo!!
Old 12-25-2015, 06:56 AM   #6
Ford Idaho's Avatar
Look at the outside access panel then go inside and look is there a bench seat or a removable panel under the fridge or in a cabinet?
As an example mine are located behind a panel held on by two screws right under the fridge.
Some are under a bed pedestal, lift the mattress and remove the sheet of wood is lays on.
Old 12-25-2015, 07:10 AM   #7
nomad297's Avatar
I think Platokidd has it right.
Bruce
Old 02-28-2016, 10:05 PM   #8
I too have purchased a winterized 2010 Cardinal 3450. I understand the concept of by passing the water heater. I would like to know the position of the valves whether open or closed. Is the valve handle parallel to the water line open or closed?
Thank anyone for your help.
jerrymc is offline   Reply With Quote
Old 02-29-2016, 07:38 AM   #9
jgump's Avatar
Jerrymc- valves are designed to be open when parallel to the pipe/line and closed when perpendicular to the pipe/line. Hope this helps.
JG
John
2016 Wildwood 27RKSS
2012 Grand Cherokee Overland (Hemi)
jgump is offline   Reply With Quote
Old 02-29-2016, 07:53 AM   #10
wmtire's Avatar
Here is a post from another thread that shows the bypass valve handle positions.
Originally Posted by wmtire View Post
Most likely your bypass valves are incorrect (very common). Do you know if they are behind the water heater (as many RV's are)? You will need to gain access to the backside of the water heater thru a cabinet, fake panel, etc. Each RV is different as to how to gain access in this aspect.
Once you do get to the backside of the water heater, then you may see either one, two, or three valves total on the water lines. The three valve system seems to be the most common.
If so, then the cold water inlet valve needs to be open, the hot water outlet valve needs to be open...and most importantly, the bypass valve, which ties the cold water line into the hot water line for winterization/antifreeze purposes needs to be CLOSED.
The valves are open when the handle is parallel with the water line it is on, and closed when the handle is perpendicular to the water line it is on. It's easy to confuse the bypass lines handle direction since the line itself runs vertically usually...but you need to make sure the handle is perpendicular to that particular line.
If the bypass valve is open, then cold water is coming in to your hot water line.
Here is how you want it:
2011 Flagstaff 831 RLBSS
I’ve lost my scapegoat.
bypass, hot water, water
