Old 10-20-2017, 02:01 PM   #1
Ray333's Avatar
Hot Water Drain Valve
Looking for a replacement for the drain valve on my HWS. See pic - does anyone have a part number or vendor for one of these. Mine is cracked and leaking (hence the duct tape)
2014 FR Rockwood Signature UltraLite 8285IKWS
Ray333 is offline   Reply With Quote
Old 10-20-2017, 02:06 PM   #2
Fulltime family RVer
Your pic didn't make it...
ependydad is online now   Reply With Quote
Old 10-20-2017, 02:09 PM   #3
Ray333's Avatar
updated now - thanks
Old 10-20-2017, 02:15 PM   #4
Ohh, I asked a similar question a couple of years ago:
Sigh, lost low point drain caps (SabreSam?)
You're after a 1/2" NPT ball valve. It makes it simple to add an easy shut-off.
Old 10-20-2017, 02:16 PM   #5
BooBoo23's Avatar
Looks like the hot water side of your low point drain. Just measure the pipe size and go to Home Depot or Lowes and tell them what you have and they can supply your with a replacement fitting. While you are at it install a ball valve on the end so you don't have to mess with it when you winterize next time.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
BooBoo23 is offline   Reply With Quote
Old 10-21-2017, 12:09 PM   #6
Send a message via AIM to jk31668
does using the red drain take the place of removing the anode rod to drain the water heater?
2010 sunseeker 3100ss
jk31668 is offline   Reply With Quote
Old 10-21-2017, 12:19 PM   #7
No. Pull out the anode rod and flush the water heater to get the crud out of the bottom to keep it from getting into the rest of the water system. You may need a new rod if yours is used up. I have a Suburban and takes a 1-1/16 socket to remove the plug at the bottom that has the anode rod. Jay
Jay2504 is offline   Reply With Quote
Old 10-21-2017, 12:30 PM   #8
BooBoo23's Avatar
Open the pressure relief valve on the WH before you remove the anode rod or you will get your Saturday eve shower early. After you remove the anode rod flush the bottom of the tank out to remove any residual crud from the anode rod.
KT4W
Old 10-21-2017, 07:11 PM   #9
SailorSam20500's Avatar
Nope.
First, hot water leaves the tank from the top, so draining hot side will leave the tank mostly full. Cold drain might drain more, but that may pull crud back into your plumbing.
In any case, you should to take a look at the anode to see how much wear it has. Replace it if it is getting really skinny, some folks replace it annually regardless of wear. Also take the time to rinse as much crud out of the water heater as possible. I've seen recommendations that filling the water heater with a strong vinegar solution and leaving it sit overnight with either propane or electric keeping it hot will remove most of the scale build up if there is much in there. Take a look at: http://www.loveyourrv.com/cleaning-r...-tank-vinegar/
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2018 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 10-22-2017, 08:26 AM   #10
Wolverine 1945's Avatar
I bought one @ our local RV dealer as soon as I found we had a caped line,,, just incase we lost one !!!
Wolverine 1945 is offline   Reply With Quote
hot water, water, drain, valve
