Old 02-17-2015, 12:32 PM   #11
Witch Doctor's Avatar
Originally Posted by DickiedooFlagman View Post
The 6 gallon Suburban HW tank in our Flagstaff allows both propane and electric to be used at the same time.
best way for quick recovery, plus the Navy Shower....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 02-17-2015, 02:56 PM   #12
UncleBobby's Avatar
Yea
I had both gas and electric on at the same time,
I had a 6 gal in my Georgie Boy maverick class c, an the heater in that could keep up with shower demands and it was gas only
Living the life
UncleBobby is offline   Reply With Quote
Old 02-17-2015, 03:00 PM   #13
wmtire's Avatar
As others have pointed out, you may have an incorrectly (or faulty) bypass valve.......or you also have the outside shower taps on, but shut off at the handheld wand. This also allows cold water to mix in with the hot water.
Might want to check to see.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 02-17-2015, 03:01 PM   #14
TURBS's Avatar
I have to wonder if the bypass valve isn't stuck partially open allowing cold to mix with hot.
I had a 6 gallon in my flagstaff and we managed with a family of 7
TURBS
Old 02-17-2015, 03:15 PM   #15
Boss Ox & Drovergirl
oxcamper's Avatar
Our 6 gal Surburban heater gives sufficient hot water to shower for about 7 minutes full on. with the "Navy" shower, you can take your time. One thing that hasn't been mentioned is the gpm of the inlet pressure (use a pressure regulator at ~55psi?), or if you use the fresh tank and water pump do you get better results. I wonder if the inlet pressure is too high, you'll just push water through and not allow it time to get hot as you deplete the supply.
Hope you figure it out.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 02-17-2015, 03:16 PM   #16
oxcamper's Avatar
Question everyone< what is the purpose of having both electric and gas on? Quicker recovery?
Old 02-17-2015, 03:20 PM   #17
Yes, it heats faster
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2017- 16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 02-17-2015, 03:20 PM   #18
Yes, plus 142d thermostats help also by requiring less hot water and more cold.
Old 02-17-2015, 03:31 PM   #19
Yes, quicker recovery. Eliminates the second person from %@#^%$&^$%(.
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
Old 02-17-2015, 03:32 PM   #20
UncleBobby's Avatar
Does anyone know what the factory thermostat setting is
Living the life
hot water, show, shower, water
