Old 02-16-2015, 01:49 PM   #1
UncleBobby's Avatar
Hot water getting cold after less than 2 min in the shower
So i bought a 2015 flagstaff SL 26FKWS a couple weeks ago
Took it out this past weekend and the water heater doesn't keep up in the shower, after about 2 min the hot water is gone,
Anyone have any suggestions before i take it into the dealer?
Living the life
UncleBobby is offline   Reply With Quote
Old 02-16-2015, 01:56 PM   #2
Berkshire 390QS
NO3putt's Avatar
Double check that you have the WH bypass values set correctly, if you happen to leave the middle one open, your mixing cold water with hot.
NO3putt is online now   Reply With Quote
Old 02-16-2015, 01:58 PM   #3
Ret E-9 Anchor-clanker
donanddona's Avatar
If it is a 6gal water heater it doesn't last long. I being a retired navy guy fit in easy to the wet-soap-rinse showering. Never have a hot shower. Usually a "kool" shower will yield enough time to soap your hair but ya gotta be quick. Sorry, it is what it is. Some have installed a fancy mod to allow those Hollywood showers.
donanddona is offline   Reply With Quote
Old 02-16-2015, 01:58 PM   #4
DaveSchwartz's Avatar
The bypass valves on the back of the heater are probably in the 'winterizing' position. When you open up whatever you have to do to get to the backside of the heater, there are three valves... one each on the hot and cold inlet pipe and one connecting the two. When the handle is perpendicular to the pipe, the valve is closed - when its in-line with the pipe, its open. For winterizing, the hot and cold inlet are closed and the bypass between them open. For normal use, reverse all three.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 02-16-2015, 04:56 PM   #5
Also make sure you have the thermostat set to its highest setting.
2008 FR Salem 26TBUD
2010 FR R-Pod 171 (2009-2015)
2010 Chevy Suburban
Honda EU3000is inverter-generator
techntrek is offline   Reply With Quote
Old 02-16-2015, 05:02 PM   #6
Thermostats are non-adjustable. They have to be replaced. I replaced both the propane and the 110v with 142Degree ones.
Old 02-16-2015, 06:04 PM   #7
sounds like everything is working fine... (if its a 6gal tank which is whats listed)
your shower head is likely a typical ~2.5gpm (should be right on the shower head), assuming you get 100% recovery from the tank which is not likely as some is wasted heating the line and the 'tail end' will be cool due to the fresh water filling the tank, getting 2min of HOT water is all youve got.
With a tank like that you had better be taking fast showers, or take navy showers (turn water off while washing hair or soaping up)
'14 XLR 395AMP
'16 Ram 3500 DRW, 6.7 cummins w/aisin trans and 4.10 gears
ykdave is offline   Reply With Quote
Old 02-16-2015, 07:45 PM   #8
Check your outdoor shower to be sure those valves are not open and the shower head valve closed. That will cause your water to go cold sooner than it should.
Sent from my KFSOWI using Tapatalk
2016 Ram 2500HD 6.4L Crew Cab 4X4
2007 Dodge Ram 1500 MegaCab
2014 Rockwood 2703WS
thecigarmann is offline   Reply With Quote
Old 02-16-2015, 09:45 PM   #9
UncleBobby's Avatar
Thanks for the replies,
Ill check it out this week and ill post up what i come up with
Thanks again
Living the life
Old 02-17-2015, 12:19 PM   #10
Living the life
The 6 gallon Suburban HW tank in our Flagstaff allows both propane and electric to be used at the same time.
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
hot water, show, shower, water
