My Flagstaff has a switch on the wall by the bedroom door, where the A/C controls and tank level indicators are that says "water heater". When switching from gas to electric, you have a hidden power switch under the outside ventilation cover. Once that is on, you have to be sure your breaker in the WFCO power center is on, then I flip my rocker switch on the wall to the on position, and it lights up red. I then wait for about 10 seconds while the automatic system takes over. Once it's on, the light goes off. You now have hot water (after about 15 mins.) Hope this helps you! Randy
