Old 01-22-2012, 02:46 PM   #1
Liltrouble728's Avatar
Hot water heater from propaine to electric
How to switch hot water heater from propane to electric on a 1998 wildwood 5th wheel? My father just bought a used wildwood with no owners manual and is trying to not use his propane to heat water wants to use electrical any ideas?
Liltrouble728 is offline   Reply With Quote
Old 01-22-2012, 02:48 PM   #2
bikendan's Avatar
hard to say on that old of a rig.
if it's a Suburban WH, they usually have the electric toggle switch on the WH, accessed from the outside WH panel.
propane is usually activated from inside.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 01-22-2012, 02:57 PM   #3
My husband and I just bought a surveyor sp240 and when we did the pdi they showed us where the hot water pump drain is you pull the pin and flip the switch to on in order to switch it. He just switched it to I but is there anything that has to be turned off or on differently being new to RV camping I'm unsure.
Old 01-22-2012, 03:29 PM   #4
bikendan's Avatar
if the WH's electric toggle switch is on and there's no water in the WH, the electric element will burn out.
NEVER turn it on, without any water in the WH.
Old 01-23-2012, 03:42 AM   #5
cardinal4fun's Avatar
First off, with units of that age group I do not think they came with the electric heater option. I could be wrong however. If it does have the electric heating rod the switch will be located on the outside of unit behind the heater cover. You may also check the main electrical breaker pannel in the unit to see if there is a breaker for the water heater.
3500 Ram 5.9l diesel
08 35 RLT Cardinal
5th Airborne Pin Box
cardinal4fun is offline   Reply With Quote
Old 01-23-2012, 05:41 PM   #6
We found the switch it is in the same location that ours is on out 2012 surveyor, from the sounds of it all is working well thanks for all the replies!
