Old 12-20-2015, 11:55 AM   #11
A32Deuce's Avatar
The outside switch is for electric element inside switch is for gas. Doesn't sound like you turned on gas side!
A32Deuce is offline   Reply With Quote
Old 12-20-2015, 11:58 AM   #12
In Post #1 He turned on the Gas side ,thats how he had Hot water! Youroo!!
Old 12-20-2015, 12:02 PM   #13
RedStick's Avatar
I thought I had a full hot water heater before I turned on the outside switch for electric.
I ran water in the bathroom and kitchen, then went outside and checked at pressure release BEFORE I turned on switch to electric hot water outside. I've done this every time.
I had zero air and waited a bit before I hit the on switch outside.
This morning, when I realized that I didn't have hot water I did press the inside gas switch - but I'm still not receiving hot water.
Also I can not turn off the outside electric switch now. Stuck in the ON position.
I'm at a loss! I'm guessing the heating element did fry or the switch is bad.
2013 Rockwood Roo 23ss
2012 F150 Ecoboost
Camped for 12 nights in 2015 - too many cancellations
Camped for 25 nights in 2014!
Camped for 24 nights in 2013!
RedStick is offline   Reply With Quote
Old 12-20-2015, 12:03 PM   #14
RedStick's Avatar
In my earlier posts I got them backwards.
2012 F150 Ecoboost
Old 12-20-2015, 12:03 PM   #15
A32Deuce's Avatar
Sorry you got it backwards. Added a lot of confusion. It may be fried on the elec. side , but gas should work unless reset went bad at the same time.
Old 12-20-2015, 12:06 PM   #16
RedStick's Avatar
I just read it again, he turned on the outside switch for gas. No that's electric on a suburban WH.
Yeah, correct. I turned them around in my brain...puzzled.
I only ran electric up until this morning when I flipped the switch inside to see if gas will work.
It hasn't so far, so I think the heating element is fried. I don't know how it happened though.
Doesn't explain why I can't turn off the electric switch outside though.
2012 F150 Ecoboost
Old 12-20-2015, 12:10 PM   #17
A32Deuce's Avatar
Easy enough to change. Been there/done that. Like I said, gas should work, just takes a little time. You can run both at the same time. Great at shower time. Faster recovery!
Old 12-20-2015, 12:15 PM   #18
RedStick's Avatar
Thanks for the help but if the heating element is fried, gas can still heat the water?
That doesn't appear to be working right now.
2012 F150 Ecoboost
Old 12-20-2015, 12:15 PM   #19
Flybob's Avatar
Behind the black rubber boots on the over temp switches are snap discs. One is for electric and one for gas. If they trip, when they are pressed you will feel them snap back on. If you pushed them and they did not move, they were most likely not tripped. As mentioned above the outside WH switch has hole through it that allows a pin to be inserted, but I believe it can only be inserted in the off position to prevent accidentally turning it on. Worth a check anyway.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 12-20-2015, 12:17 PM   #20
If the switch will not move I believe that you had a short that may have melted the inside of the switch in to the on position. If the short is in the wrong place then your gas will also not work. For the record I understood what you were saying from the first post. I just now came on line.
j free is offline   Reply With Quote
heater, hot water, water, water heater
