Old 12-20-2015, 12:53 PM   #31
Make sure your outside shower hot and cold are shut off. Brother - in - law had similar problem until he shut off outside shower.
bobkatz5 is offline   Reply With Quote
Old 12-20-2015, 12:54 PM   #32
Pickin' & Campin'
Originally Posted by bubbles View Post
I did not read where the OP has said the CB for the heating element is not tripped as mentioned early on. This may help explain the electric side of the issue. Sounds like the heater has gone into lockout also for the DSI side.
Post # 3 said he tried to reset them but didn't notice a click or anything out of the ordinary.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 12-20-2015, 01:13 PM   #33
My switch also went bad melted in the on. Had to turn it off with the inside breaker until I replaced it with a switch in the motor home.
We camp on earth with a Sun Seeker 2300
yworrydog is offline   Reply With Quote
Old 12-20-2015, 01:17 PM   #34
Don't know which model you have, but here's a manual for some of them.
2011 Traverse LT, 3.6L, FWD
Old 12-20-2015, 01:27 PM   #35
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
If the OP is going to replace the electric heating element, I'd like to remind him to purchase a socket made especially for unscrewing it. I had to make a 2nd trip to the RV store when I fried my heating element because I ASS-U-MED it was the same size as the anode and it isn't. It's not expensive, you'll always have it and might be able to loan it to someone sometime.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 12-20-2015, 01:31 PM   #36
RedStick's Avatar
Thanks for the suggestion!
I watched a YouTube video this morning. The job seams easy enough but that socket will come in handy.
The good news is this doesn't appear to be the end of the world, except that for some reason I feel the switch fried (the one on the hw heater outside).
I am not receiving hot water via gas either, by the way.
Thank you all for your suggestions. I didn't help matters as I got the two switches confused!
2013 Rockwood Roo 23ss
2012 F150 Ecoboost
Camped for 12 nights in 2015 - too many cancellations
Camped for 25 nights in 2014!
Camped for 24 nights in 2013!
RedStick is offline   Reply With Quote
Old 12-20-2015, 01:46 PM   #37
RedStick's Avatar
Additionally, when I turn on the GAS hw switch to on via the control panel inside the Roo, the button doesn't light up like it should. I just realized that.
Any cause for that? Seems like I've got several issues going here.
2012 F150 Ecoboost
Old 12-20-2015, 02:09 PM   #38
Pickin' & Campin'
Check your 12v fuses. The WH needs 12v to use the LP side of the WH.
Maybe when the 110v side of things went south it blew a fuse?
In theory they are separate systems but without seeing what possibly melted with the switch/element, it 'may' have shorted something else as well.
Old 12-20-2015, 02:37 PM   #39
RedStick's Avatar
Any other fuse locations besides the main panel and the one for my slide (located outside underneath the RV)?
2012 F150 Ecoboost
Old 12-20-2015, 03:17 PM   #40
A32Deuce's Avatar
WH will be in the main panel.
A32Deuce is offline   Reply With Quote
heater, hot water, water, water heater
