Old 12-25-2015, 03:01 PM   #61
If you have a multi-meter, you can check the heating element. If shows essentially zero ohm resistance, replace it.
2011 Traverse LT, 3.6L, FWD
Old 01-16-2016, 11:43 PM   #62
RangeMaggotBob's Avatar
Originally Posted by A32Deuce View Post
You can run both at the same time. Great at shower time. Faster recovery!
I never even considered or thought of that. Is this true? You can run both at the same time?!?
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2000i generators
RangeMaggotBob is offline   Reply With Quote
Old 01-16-2016, 11:53 PM   #63
Evereddie's Avatar
Yes and it really speeds up hot water recovery time.
Evereddie is offline   Reply With Quote
Old 01-17-2016, 12:29 AM   #64
We usually turn the gas off once heated and leave just the electric on till shower time. Kick the gas back on for showers and we can all get thru (Usually 4 of us) with minimal wait time.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
Old 01-17-2016, 01:15 AM   #65
Thanks you guys! I really appreciate it.
Old 01-17-2016, 10:57 AM   #66
RedStick's Avatar
I thought I'd provide an update to the issues a few weeks back.
We are currently camping for the long weekend. All systems go!
Once the parts arrived and I carved out some time, I ended up replacing the gas switch located on the control panel - that was a quick fix.
I then ended up replacing the electric switch outside.
Everything else checked out ok - the heating element and everything else looked fine, and tested fine.
I guess the switch outside just fried, and the switch inside had a short as I was able to get that to work previously.
So far so good.
2013 Rockwood Roo 23ss
2012 F150 Ecoboost
Camped for 12 nights in 2015 - too many cancellations
Camped for 25 nights in 2014!
Camped for 24 nights in 2013!
RedStick is offline   Reply With Quote
Old 01-19-2016, 06:35 PM   #67
MNtraveler's Avatar
Glad to hear it's resolved. Also glad to learn about the dual heating trick. 😃
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
heater, hot water, water, water heater
