Old 09-02-2014, 10:18 AM   #1
Hot water heater on Electric
So yesterday when leaving our campground, i turned off the water, and used the drain valves to bleed off any remaining water. I failed to turn off the Hot water heater on electric when I did. I am guessing that I blew the element. Anyone know the Part number or Where i can order one somewhat quickly?
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 09-02-2014, 10:24 AM   #2
kenandterry's Avatar
It would help a lot if we knew what model and size of water heater. I'm guessing a Suburban brand as opposed to Atwood. You should be able to get some of the info somewhere inside the door to the unit.
Camping World carries most parts........if not a local RV parts place. It's not a huge job to remove the element and take it with you.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 09-02-2014, 10:26 AM   #3
AKA: 'tiredTeacher
awellis3's Avatar
And I'm guessing you're wrong. Draining the system at the low point drains usually won't empty the HW tank. When you unpugged the electric, the heating element shut down. It may have not been on at all depending on water temp. I would assume it is ok and test it out at your earliest convenience.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 09-02-2014, 10:40 AM   #4
Infractee
I have no idea on his but on mine if I open low point drains it will completely empty my HW tank along with all the lines.
RhoZeta is offline   Reply With Quote
Old 09-02-2014, 10:54 AM   #5
Not necessarily. If you had already disconnected your shore power prior to that you should be golden. Bet you don't forget again
rana is offline   Reply With Quote
Old 09-02-2014, 11:24 AM   #6
i know that my Low points drain the Hot water heater. Also, i am positive that I turned the electric off last. it was hot and wanted to keep the AC going.
Old 09-02-2014, 11:29 AM   #7
wmtire's Avatar
KyDan has a tutorial in the replacement of the electric element in the FAQ section here on the forums, along with where to buy.
I know offhand the stock element is usually 1440 watts on the later Suburban water heaters.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 09-02-2014, 11:43 AM   #8
Make sure you buy the wrench to remove the element.
Old 09-02-2014, 11:50 AM   #9
Rugged Brown's Avatar
In my case the wrench cost more than the element and it ended up to be a faulty switch, not the element.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 09-02-2014, 12:11 PM   #10
If you have a freight harbor nearby you can pick up a wrench for around $6. Last I saw.
electric, heater, hot water, water, water heater
