Old 07-13-2013, 06:40 PM   #11
Send a message via MSN to Tiggerdad
My 2013 Crusader also does not light when when on. Only comes on when there is a problem. IMO, a dumb design. One can have either or both on at same time. A red light when on would prevent a lot of people from leaving on by accident.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 07-13-2013, 07:59 PM   #12
LKicklight's Avatar
Water Levels
Already knew that, at least the water heater was still full of water from our last trip out recently, plus DW had used the hose from our house which also kept the water heater full. Our sunnybrook has run very successfully in the past with both switch's in both modes with no problem. Whenever there is hot water in the heater, the electrical mode will cut off and only use the propane. Leaned that the hard way before we purchased the Crusader:
Originally Posted by sail2liv View Post
Rocker switch on panel and red light when in gas mode light up.....electric is on water heater thru outside access, a rocker on off switch with no light....both can run at same time, but if no water in tank you burn up the electric heating element...
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 07-13-2013, 09:23 PM   #13
Denver, CO
garbonz's Avatar
The red light is only onif the gas does not light and locks itself out.
2007 Chevy 2500HD Classic LBZ Duramax/Allison (Stock)
2005 Bigfoot 1500C8.2 AWESOME
Old 07-13-2013, 09:30 PM   #14
TURBS's Avatar
Install lighted switches when turned on such as mine.
Easy as pie!
Speaking of pie I'm hungry. ....
TURBS is online now   Reply With Quote
Old 07-13-2013, 10:20 PM   #15
timarti's Avatar
Different trailers seem to have different setups! On ours, the inside water heater switch (blue light) controls the propane water heating only. To use electric heat a small rocker switch in the water heater compartment needs to be turned on. For really fast heatup, both can be used together. Just have to make sure the electric heater is off before draining the tank!
Tina & Ted & pooches
2012 Ford F-150 XLT 5.0L V8 4x4 with tow package
Andersen WD hitch with sway prevention
2012 Rockwood UltraLite 2304s trailer
timarti is offline   Reply With Quote
