Old 08-26-2012, 08:07 PM   #1
Hot water heater only works w/ gas
Our hot water heater only works while in propane mode. We've given it ampleturns to heat up with electricity, but it never does. Even when we switch from gas back to electric, it cools down. Is there a simple solution.
bjlowe is offline   Reply With Quote
Old 08-26-2012, 08:36 PM   #2
Herk7769's Avatar
The troubleshooting on the AC side of a dual propane/electric water heater is pretty straight forward.
Make sure the circuit breaker in the panel that feeds the water heater is set
Make sure the on/off switch is ON
Press both rubber disks that cover the high limit reset buttons
If that does not get you going:
Remove the rubber protective covers on the high/low limit thermostats
Examine them for melted connecting fuse link like the left one in the photograph
Replace thermostat if melted
If power is going to the electric heating element and still no heat; replace it.
Name:	AC diagram.jpg
ID:	18727   Click image for larger version
ID:	18728   Click image for larger version
Name:	Limit Switch Reset.jpg
HAM CALLSIGN - KC3FFW
Old 08-26-2012, 09:16 PM   #3
Wow Lou, great information!! I'll check on this when we take the camper out this Friday for Labor Day weekend and let you know!
Old 08-26-2012, 10:42 PM   #4
Herk7769's Avatar
LOL - We get this one a lot.
Old 08-26-2012, 10:57 PM   #5
B47
Lou - you say "Remove the rubber protective covers on the high/low limit thermostats."
My Suburban WH manual only says to press the covers if the WH doesn't run on AC. Is that a fix (replacing melted fuses) that you discovered or that a generic fix for all RV WH nakes?
Old 08-27-2012, 06:41 AM   #6
Herk7769's Avatar
Every water heater out there (except perhaps the "on demand" types) have some form of high/low limit thermostat. There are two in units that run on propane and AC because they are two separate and independent systems that share a water tank.
The reason is there has to be a way for the water heater to decide the water is hot enough to shut off (high limit thermostat opens) and cold enough start (low limit closes). The unit is sold as a "set" of thermostats and the thermostats are connected by a fusible wire.
As I said there are two different ones; one for AC (black wires) and one for the DC control of the propane burner (red wires) in this photo.
The reason the manual stops at pressing in the rubber covered buttons is that there is power on those thermostats (120VAC in the case of the one on the left) and you could get shocked if you don't know what you are doing.
If the high limit thermostat "bellows" gets stuck open, the electric will not heat the water. Pressing on then rubber disk will collapse the bellows and close the circuit. If the fusible wire is gone, this will not fix the problem and the entire thermostat unit must be replaced.
The Atwood thermostat looks like :
Atwood 140° Thermostat Kit with ECO, #91447
The Suburban one like
RV Suburban Water Heater Thermostat/High Limit Switch, Part # 232319 | eBay
They are not expensive and with care (and some electrical knowledge) are easy to fix.
This is from the Suburban manual.
ID:	18741   Click image for larger version
Old 08-27-2012, 08:38 AM   #7
B47
Thanks for the explanation. The reason for asking is because I assumed that hecause the manual didn't mention "fuses" that there were only circuit breakers under the disks and no fuses.
Old 08-27-2012, 08:53 AM   #8
Herk7769's Avatar
Now you can see it is not a "circuit breaker" per se, but a bellows switch that can get stuck open that you manually compress "closed."
Old 08-27-2012, 01:34 PM   #9
B47
Yep - I see that now.
Thanks.
Old 08-28-2012, 12:24 PM   #10
Herk.
FR service team replaced my HW element with newer model not so susceptible to burn out. Btw free service for those at Frog Intl Rally
Do you know any details on this newer element??
Roy & Jean
2010 Rockwood mini Lite ETC 181
2002 Toyota Tundra 4.7l 4x4
Prodigy P3, E2 WDH
rschoono289 is offline   Reply With Quote
