Old 04-30-2011, 04:57 PM   #1
Hot Water heater Problem
I have a 2011 - 3002W Windjammer. My hot water is only LUKE WARM AND NEVER HOT when I run it on electric...again, never hot. What do I need to do? Help!!!
dsherold is offline   Reply With Quote
Old 04-30-2011, 05:05 PM   #2
MtnGuy's Avatar
1st of all, I would make sure the bypass valve is completely closed.
Old 04-30-2011, 05:24 PM   #3
sherdep's Avatar
2nd think is to make sure it has water in the tank prior to turning it on or you will fry the element
you turning it on the gas or electric?
Like stated above verify you not in Bypass cause that will most definate cause no hot water
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 05-01-2011, 10:24 AM   #4
bikendan's Avatar
outside shower has been known to also cause this problem.
Old 05-06-2011, 05:49 PM   #5
poorturtle's Avatar
Luke warm water
If the electric element is burned out the water will get luke warm but it takes a while to heat. The water has some resistance [impurities] and this is the result. Hope this helps.
2011 Sabre Palomino
2006 Chevy 2500 Duramax 4x4
Camp Verde, AZ
poorturtle is offline   Reply With Quote
Old 05-06-2011, 06:22 PM   #6
Herk7769's Avatar
Airxcel | Suburban Manufacturing Service
Good link for help with Suburan Water heaters. If anyone has the PDF please post it.
HAM CALLSIGN - KC3FFW
Old 05-06-2011, 07:23 PM   #7
frankm's Avatar
Here are the Suburban manuals for the 6 and 10 gallons water heaters.
poorturtle, I'm think with these single heating element WHs if the element burns out the water would be cold and not luke warm.
subsw10.pdf
subsw06.pdf
Frank & Rita M
2016 Ford F-150 XLT Ecoboost
2017 Rockwood 2703WS
frankm is offline   Reply With Quote
Old 05-06-2011, 10:33 PM   #8
Herk7769's Avatar
I have the 6 gallon one; Thanks Frank
Old 05-06-2011, 10:43 PM   #9
poorturtle's Avatar
Just reporting findings
On my Trail Bay last year I experienced a burnt out element. I never realized the elemet was out as the unit was operating on LP for the season. When the weather turned cold in the fall I left the electric on to prevent a freeze up. The next time we used the unit I tested the water and found it to be luke warm. Being an Engineer I just had to know why. A local chemist explained the process to me. I report...you decide. Thanks for listening.
2011 Sabre Palomino
Camp Verde, AZ
