Old 12-08-2018, 11:23 PM   #1
Hot water heater problems in a Cherokee 274vfk.
We purchased a new 2019 Forest River Cherokee 274vfk. We love everything about the RV except for the performance of the hot water heater. Our previous Starcraft RV had a manual-light gas 6 gallon Suburban hot water heater and my wife and I could take showers one after the other and never run out of hot water. The Suburban hot water heater in our new RV is also a 6 gallon Suburban gas & electric but it won't put out enough hot water to get through even one military-type shower. The burner lights and the electric element will power on.
When I was winterizing the RV, I turned the bypass valves on the inlet and outlet of the hot water heater but there was no third valve in the bypass line. I called the dealer and was told that there was a check valve in that line next to the water heater. I don't see how a check valve could work as the flow direction is the same through the water heater or the bypass hose.
Anyway, I'm going to install a manual valve in the bypass hose. I think that this is going to fix the problem with the hot water heater.
Have any of you encountered this?
Bill J., Lexington, KY
whjco is offline   Reply With Quote
Old 12-09-2018, 12:52 AM   #2
cavie's Avatar
you have a two valve system they work very well. do a search. you do not need a check valve.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 12-11-2018, 03:20 PM   #3
Commercial Member
ES_FR's Avatar
whjco,
We would be happy to assist you with this question regarding your water heater. Please contact Mikala Yoder in our Customer service department through the following personalized and direct link: Forest River RV Direct Service Contact - Forest River, Inc..
This direct link is provided for your convenience in order that we may resolve your concerns as quickly as possible. We will strive to respond to you within 24 hours of receiving your correspondence.
Respectfu
ES_FR is offline   Reply With Quote
Old 12-11-2018, 03:39 PM   #4
Flybob's Avatar
Did you check the outside shower? What you are describing can be caused by the faucets in the outside shower bring open.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 12-11-2018, 03:46 PM   #5
cavie's Avatar
Here is the correct picture for the 2 valve system There is no check valve.
Old 12-11-2018, 07:08 PM   #6
Oaklevel's Avatar
We have had both the two and three valve shut off "bypass winterizing" valves. Both work fine. There is absolutely no difference in the performance of the systems when water heater in actual use.
As others have mentioned check your outside shower valves.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 12-16-2018, 06:09 PM   #7
Thanks for the tip. However, outside shower valves are closed and not leaking.
Old 12-16-2018, 06:11 PM   #8
Attachment 192934
Our hot water heater has the same setup, so I guess the valves are two-way valves.
I have everything drained and winterized so I can't troubleshoot any further. Looks like I'll be doing some more troubleshooting as soon as winter freeze season is over.
Thanks for your response!
Bill J., Lexington, KY.
Old 12-16-2018, 06:13 PM   #9
Originally Posted by ES_FR View Post
whjco,
Respectfu
Mikala, thanks for your response and for the quick responses to my subsequent communications. I'm impressed with Forest River's Customer Service. Thanks for taking such good care of us!
Old 12-16-2018, 06:38 PM   #10
Flybob's Avatar
Most outside showers have a shut off valve in the shower head and will shut off the water ( no leaks) even if both the hot and cold faucets are open. If those valves are open cold water will mix with the hot and can cause the issue you are seeing.
TST Tire Monitors
2 100W solar panels
cherokee, heater, hot water, water, water heater
