The danger of leaving the WH on is that if you are in electric mode and the water heater drains ( intentionally or otherwise) you will burn up your heating element is seconds if you connect to shore power. Many times this happens when people connect to shore power at home to clean RV or prep it for the next trip. In propane mode, the heat could damage the tank or trip the over temp protection. I always turn off my WH when I break camp.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
