05-31-2018, 11:16 PM
#21
The camper was in a flood aprox 3 inches of water above the floor for a very short time so i belive that may have been the cause of the pump failure.
06-01-2018, 04:37 AM
#22
Yeah, that could do it.
2011 Flagstaff 831 RLBSS
06-01-2018, 05:06 AM
#23
You'll need to check the fresh water tank for flood water intrusion as well and depending on their location, the furnace, the converter, breaker box, CO/Propane detector, stabilizer and slide motors, etc.
Best of luck.
06-01-2018, 05:17 AM
#24
Best of luck.
Yes like the Song,"We've Only Just Begun"! Most "Flood Units" are NOT a Deal! Youroo!!
06-01-2018, 07:00 AM
#25
Have checked out all the above and all seemed ok just hafd the small issue with the valve position and pump so far
06-01-2018, 07:52 AM
#26
where is the switch to turn the hot water heater on and off?
06-01-2018, 08:46 AM
#27
Mine is on the cupbord wall just inside the entry door sll my switches are located there
06-01-2018, 03:09 PM
#28
Depends on what brand/model of water heater you have.
Suburbans generally have the propane switch inside and the electric switch outside.
Atwoods generally have both switches inside.
06-01-2018, 08:38 PM
#29
Originally Posted by Skyliner
Usually to open a valve to allow water flow, it is turned counterclockwise. If the valve has a long handle instead of a circular handle, then open is usually with the long handle is aligned with the flow of the water in valve or water supply line hose/pex/copper etc.. and closed when the handle is perpendicular to the water flow in the valve or line.
With this knowledge, you want the bypass valve closed and valves at hot water heater closed to water flow goes into and out of water heater and not bypasses it.
This picture should help you understand what a bypass is and why it is needed. Even though I've owned a camper for over 10 years, I sometimes get confused and have to think about it.
The purpose of a bypass valve is so you do not waste 6-10 gallons (depending on water heater size) of antifreeze when you winterize. Instead, you bypass the hot water heater, drain the hot water heater, and then pump antifreeze thru the RV lines and end up usuing less antifreeze.
The picture is not correct for bypass or normal use. It shows ALL valves open. Your comment says to close all valves which is not correct either. For normal use the valves to the HW heater should be open and the bypass valve should be closed.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
06-02-2018, 07:39 AM
#30
The pictures of the back of the hot water tanks are great.
Just so I do not have to think about winterization any more I printed them off and glued them to the back of the cover in the cabinet that has access to the tank.
I also threw away the screws that hold this piece of wood on and replaced it with Velcro. Much easier.
Brandon 2
2014 2500TS
Sun Seeker
06-02-2018, 10:26 PM
#31
Grey Wolf Limited as well.
If yours has an electric element as well as the propane there will be a seperste switch under the outside heater cover itself hidden on the lower left side. Depends what model water heater you have but if I recall the limited package added dsi/electric water heater.
