Old 01-02-2015, 03:14 AM   #11
Hot Water Heater
Originally Posted by SeaHarley View Post
One of the things I was able to finish today was a drain valve for the Hot Water Heater. It had a plastic drain plug that you have to completely remove in order to drain the tank. It is in a tight situation to begin with behind the gas piping and valve, etc. I viewed this to be a pain-in-the-a--.
We're gonna be doing some winter traveling and I may / will need to drain the tank after I fill it up when I reach colder temperatures up north, (we are heading South!).
So after many trips back and forth to H.D., etc. I came up with this:
First photo shows the plastic plug in my hand that I replaced.
Attachment 68003
This is a closer view:
Attachment 68004
I pulled out the Anode and it empties well, along with any anode scales.
Good Luck on your trip
TinkerToy is offline   Reply With Quote
Old 01-02-2015, 04:09 AM   #12
Salem Cruise Lite Owner
Bushbunch's Avatar
Where is the anode?
Attachment 68003
Attachment 68004
Where is the anode?
Bushbunch is offline   Reply With Quote
Old 01-02-2015, 05:34 AM   #13
wmtire's Avatar
Originally Posted by Bushbunch View Post
Where is the anode?
An Atwood water heater with an aluminum tank does not have an anode rod. It's the Suburban water heaters with the porcelain-lined steel water heater tank that utilizes an anode rod. I think this was pointed out in the earlier posts # 4,5,and 6.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
drain, heater, hot water, tank, water, water heater
