Old 12-31-2014, 07:46 PM   #1
SeaHarley's Avatar
Hot Water Heater Tank Drain Valve.
One of the things I was able to finish today was a drain valve for the Hot Water Heater. It had a plastic drain plug that you have to completely remove in order to drain the tank. It is in a tight situation to begin with behind the gas piping and valve, etc. I viewed this to be a pain-in-the-a--.
We're gonna be doing some winter traveling and I may / will need to drain the tank after I fill it up when I reach colder temperatures up north, (we are heading South!).
So after many trips back and forth to H.D., etc. I came up with this:
First photo shows the plastic plug in my hand that I replaced.
Name:	2014-12-31 16.35.05.jpg
This is a closer view:
Name:	2014-12-31 16.35.12.jpg
2012 Lacrosse, 308RES.
2013 Ford F150, XLT, 4x4, Supercrew, Eco-Boost.
Lee, Dawn and "CoCo", the dog!
2015 Overnight Camping Days = 25, States Below:
SeaHarley is offline   Reply With Quote
Old 01-01-2015, 09:59 AM   #2
WFD
Looks like a nice fix that should simplify things nicely.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 01-01-2015, 10:05 AM   #3
dcheatwood's Avatar
Great mod. I'm sure you're aware that the exposed pipe is subject to freezing sooner if water is left in it. But I like it.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 01-01-2015, 10:05 AM   #4
This Mod is for (Atwood) heaters (ONLY)! Youroo!!
Old 01-01-2015, 10:08 AM   #5
WFD
True...keep in mind this water heater does not have an anode rod.
Old 01-01-2015, 12:03 PM   #6
SeaHarley's Avatar
Correct, there was not an Anode Rod in there. Not needed with this model due to Aluminum Tank.
And I'm not worried about water freezing in this little length of pipe because that's the whole idea; to be able to drain it quickly and easily.
Old 01-01-2015, 12:08 PM   #7
SeaHarley's Avatar
I found this one on the etrailer site "after" I made my modification.
You could use this one if you had an Anode:
Camco RV Water Heater Anode Rod w/ Drain - 1/2" Diameter x 4-1/2" Long Camco RV and Camping CAM11533
And they have one without the Anode as well, but the rotating handle is still back in the way of the gas piping, etc.
http://www.etrailer.com/RV-and-Campi.../CAM11703.html
Old 01-01-2015, 12:25 PM   #8
Be sure to flush after each season!
Hi what ever you use to drain you water heater remove the sediments from you tank each season . I use this it works well. ;-) Camco RV Water Heater Tank Rinser - Walmart.com
fellow traveler is offline   Reply With Quote
Old 01-01-2015, 12:51 PM   #9
Flybob's Avatar
I had done a similar mod to mine. Used a nylon adapter to eliminate chance for dissimilar metal reaction. Also extends out far enough to keep crud from running down side of RV.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-01-2015, 02:59 PM   #10
SeaHarley's Avatar
That's perfect as well.
I like the nylon idea.
I'm gonna keep an eye on that interface to see if any kind of reaction is going to go on with the metals. I feel the tape helps minimize that situation.
drain, heater, hot water, tank, water, water heater
