Old 07-28-2016, 02:38 PM   #11
f5moab's Avatar
It could easily be calcium; since the water here is very high in calcium; never thought about it. Just never saw it cake up like that. However, after flushing for over an hour this AM; it appears to be running clean. But that would explain why it just dissolves when touched.
f5moab is offline   Reply With Quote
Old 07-28-2016, 02:40 PM   #12
Use one of these, https://www.amazon.com/Camco-11691-W...ter+flush+wand
bukhrn is offline   Reply With Quote
Old 07-29-2016, 07:22 AM   #13
Originally Posted by bukhrn View Post
x2 on use of this rinser.
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
Old 07-29-2016, 07:25 AM   #14
Wolverine 1945's Avatar
Ill bet the old Porta Pottie flush wand would work well also !!!
Wolverine 1945 is offline   Reply With Quote
Old 07-29-2016, 07:37 AM   #15
Use a washing machine supply hose cut in half,use one half placed into the A-Rod opening! Give the other half to a RV friend so they can "De Crud" their W/H also! Youroo!!
Old 07-29-2016, 07:55 AM   #16
You did mean a used W/M supply hose,,, Right ???
That is a good idea youroo !!!
Our any old garden hose with a female end !!!
Old 07-29-2016, 08:04 AM   #17
The washing machine hoses are Small OD,they allow the hose to "Flop around Inside the W/H while also Allowing the CRUD and Water to Flow Out the Same Hole"! And Yes any person can acquire a Used supply Hose FREE just ask any Appliance Delivery Guy! Youroo!!
Old 07-29-2016, 08:43 AM   #18
Or a pack rat like my self,,, who has I think has 4 of them hanging in the garage ???
Old 07-30-2016, 12:48 PM   #19
Team Bleu
Hi, I have a question for you. Since I bought my coach 2013 Georgetown XL, I have had this problem, one way of solving it all we had all the littles filtered removed, but we also had the toilet changed and now my toilet is getting no water at all. Do you know if there is a spot we can force air through to blow out all the toilet lines
DBsRedVett is offline   Reply With Quote
Old 07-31-2016, 06:36 AM   #20
You could hook a compressor to your city water inlet,,, and use maybe about 40 psi,,, But I am guessing there is a problem with your new potty,,,
maybe some thing in the line,,, that should be checked first !!!
PS: you would drain all the water out first !!!
heater, hot water, water, water heater
