Old 07-27-2016, 08:39 PM   #1
f5moab's Avatar
Hot water heater-white plastic particles
When draining the hot water heater, I have a lot (and I mean a lot) of white stuff draining with the water. They look like piece of white plastic, but the minute you pick one up they dissolve into nothing.
Most that come out, when they hit the asphalt they just shatter into hundreds of other particles.
Is this an inner lining that is dissolving?
f5moab is offline   Reply With Quote
Old 07-27-2016, 08:51 PM   #2
davel1971's Avatar
mineral deposits in water heater. Need to change anode rod and flush tank out while rod is out.
David & Lynn
Old 07-28-2016, 08:09 AM   #3
f5moab's Avatar
Anode is almost new. Been flushing, but this stuff is flat, which is what makes me wonder what it is.
Old 07-28-2016, 08:17 AM   #4
Flybob's Avatar
Calcium or other mineral deposits . The amount will vary with the quality of the water. If you are getting a lot, I would drain after ever 1 or 2 trips.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 07-28-2016, 08:22 AM   #5
The Real RV name of this "Stuff" is White Crap or Crud" I have never see a A-Rod removed after Some use that did not have "Crap or Crud" flow out also! Youroo!!
Old 07-28-2016, 08:34 AM   #6
bubbles's Avatar
Calcium deposit. Remove the electric element (if equiped) to see deposit buildup on bottom of tank. Veneger will desolve it.
Old 07-28-2016, 10:28 AM   #7
raspivey's Avatar
I'm thinking it may also be some of the anode rod disolving. I don't like the idea of any of that being sucked into my plumbing, so I drain the water heater after each use. Before I leave, I'll just hold a garden hose tightly up against the anode rod opening with the relief valve closed and the heater in bypass for about 30 seconds. Yank the hose out of the way (make real sure you're not standing in the way or you'll get wet) and the pressure will blow anything loose out. I do that two or three times before installing the rod and putting it back in service. You could use one of those tank wands too, but this does the job well enough.
2012 Chevy Tahoe LTZ - HD tow package
raspivey is online now   Reply With Quote
Old 07-28-2016, 10:41 AM   #8
Mr. Dan's Avatar
I wouldn't remove the electrical heating element... no need. I'd remove the anode rod which the OP is surely doing to drain the heater.
SEARCH is your friend!
Nights Camped: 2013 = 49 / 2014 = 74 / 2015 = 74 / 2016 = 85
Old 07-28-2016, 10:43 AM   #9
Devilscreekw's Avatar
Good hint...will try that next time.
Harv & Deb
2015 Flagstaff 27RLWS
2010 Ram 2500 4x4 crew 5.7 Hemi, 3.73
Equalizer 1200 4 pt. Tekonsha controller
Devilscreekw is offline   Reply With Quote
Old 07-28-2016, 11:49 AM   #10
indybp57's Avatar
That stuff will eventually clog your sink aerator. You may also have it in your home water heater. Changing from an aluminum rod to magnesium is reported to prevent it but i haven't tried it yet.
Sent from my 9020A using Tapatalk
2013 Roo 183
2012: 1042 Miles, 13 Nights camped
2013: 2772 Miles, 27 Nights camped
2014: 2259 Miles, 30 Nights camped
2015: 1644 Miles, 20 Nights camped
2016: 550 Miles, 11 Nights camped
indybp57 is offline   Reply With Quote
heater, hot water, water, water heater
