Old 04-16-2011, 11:57 AM   #1
hot water heater won"t iginte
i have a 2004 salem travel trailer that i park @ a campground. this year when i just hooked up the water the heater won't ignite? gas tanks are full. have tried turning on the switch several times. read the manual which was no help. anyone have any ideas?
fitz502 is offline   Reply With Quote
Old 04-16-2011, 03:18 PM   #2
DAISY BOYKIN's Avatar
HOT water tank will not lite !
Bleed the air out of the gas line ?????
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 04-16-2011, 04:55 PM   #3
bikendan's Avatar
first, does the WH have DSI or is it lit manually?
second, make sure all the air is out of the gas lines by turning on the stove's burners until they are burning consistently. this helps purge air in the gas lines.
then try lighting it again.
if this doesn't work, something with the igniter is wrong.
