Old 01-10-2018, 12:12 AM   #1
Hot water in lavatory and kitchen sinks, but only luke warm in the shower
I have a 2014 Georgetown 377XL that I put an on demand water heater in last season (Precision Temp RV-550). All worked well with real HOT water reaching all faucets. I took it in for some warranty work and the dealer kept it so long that they "winterized" it without my asking them to. Now I get "HOT" water in the kitchen and lavatory sinks but only luke warm water from the main shower. I have not tried the outside shower yet because that one was not winterized so it froze and split when I dewinterized (what a mess). Speaking to a plumber friend of mine he says there is a bleedover somewhere, but I cannot find anywhere that the hot and cold waterlines even get close (except on the waterheater bypass valves and I have looked). Anyone have any ideas how to correct this problem???
CarefreeCorses is offline   Reply With Quote
Old 01-10-2018, 12:14 AM   #2
SlfMdeFam's Avatar
Plumber here... so with on demand water heaters, they turn on with a minimum water flow per minute. Check to make sure thereís no obstruction in the head slowing down the flow of water coming out which in return will lower the flow through the water heater not telling it to turn on all the way.
Good luck.
SlfMdeFam is offline   Reply With Quote
Old 01-10-2018, 12:22 AM   #3
2018 Rockwood 2703WS
Houston Remodeler's Avatar
also check the outdoor shower to be turned fully off on the hot and cold sides as this can act as a mixing valve
2014 Ram 2500 4x4 diesel
guarded by our Jack Russell
Houston Remodeler is offline   Reply With Quote
Old 01-10-2018, 12:22 AM   #4
Not clear what state your outside shower is in, but if the faucets are open and the shower head is turned off with the little button, you will be mixing hot water and cold and it can show up in your shower; just like having the bypass valve open on a normal Suburban or Atwood water heater.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 01-10-2018, 11:24 AM   #5
Check this thread:
NO (OR LUKEWARM) HOT WATER -Please read first
Iwritecode is online now   Reply With Quote
Old 01-10-2018, 11:41 AM   #6
Originally Posted by Iwritecode View Post
Seems as though those posts pertain to a conventional water heater.
The OP said he installed an on demand water heater so are we really sure how it is plumbed?
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 01-10-2018, 11:49 AM   #7
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
If you have a water manifold with individual shutoffs turn the hot and cold off to the outside shower and if this doesn't work turn off the cold water for the shower in the bathroom also.
If you have a single lever shower control it could be broken or popped an O-Ring internally.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 01-10-2018, 11:54 AM   #8
cavie's Avatar
++++++ with post #2. Happened to me. Turn off both valves to your outside shower. Do not rely on the trigger valve. Been there done that.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 01-10-2018, 03:25 PM   #9
Vince and Charlette's Avatar
I've known guys in the Army (I was AF) who would consider a lukewarm shower a luxury.
2018 Berkshire 38A
Vince and Charlette is offline   Reply With Quote
Old 01-10-2018, 04:52 PM   #10
Good luck.
Chris, thanks......... I have suffucient flow to get scalding hot water in the lavatory and kitchen sinks but not in the outside and indoor showers so I would not think it would be restricted flow out from the waterheater. If it did, then the waterheater would shut down.
hot water, show, shower, sink, water
