Old 07-19-2011, 07:58 PM   #1
Wildwood1's Avatar
hot water in the toilet
on a recent camping trip i fired up the hot water tank like we always do, then a few minutes later i flushed the toilet and noticed the water flowing in (into the toilet) was steaming hot. whats up with that!! im pretty sure it was always cold water! i can understand sometimes the cold water coming from other taps is warm for a few seconds because the hot and cold pipes are close together in some areas but the water coming into the toilet seemed to be really hot (steam).
cant figure out how hot water can flow through a cold water pipe??
Kevin and Joanne
06 wildwood 27le fbss
08 dodge ram 4x4 5.7 quad cab
07 kawasaki brute force 650i
Wildwood1 is offline   Reply With Quote
Old 07-19-2011, 08:06 PM   #2
yvesm's Avatar
Sounds like the toilet water is hooked up to the wrong water line. If its a new camper take it back for warranty.
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
yvesm is offline   Reply With Quote
Old 07-19-2011, 08:10 PM   #3
By chance did one of the bypass valves get turned on your HWT this might allow hot watr to come through the cold line
CanadianRVER is offline   Reply With Quote
Old 07-19-2011, 08:12 PM   #4
Was your water hose laying out in the hot sun for a while before you flushed? It dosen't take very long this time of year.
2017 RAM 3500 DRW CC Laramie, Curt Q20
2013 CC 36CKTS
Me and DW
2 cats: Bello & Dexter (Peanut) RIP
DavandJane1 is offline   Reply With Quote
Old 07-19-2011, 08:12 PM   #5
Lottery Non-Winner
Ovair's Avatar
Is it possible that the hot water bypass valves are somehow in the wrong configuration/position and allowing hot water to flow into the cold water supply line? Is there any way for that to happen?
Ovair is offline   Reply With Quote
Old 07-19-2011, 08:18 PM   #6
Fire Instructor's Avatar
Similar happened to me once. Check your outside shower. If the valves are open, but the shower head closed, the water will "co-mingle" and be a blend at points beyond.
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 07-21-2011, 08:04 AM   #7
jimh's Avatar
have seen that happen on the showers at work.
jimh is offline   Reply With Quote
