Old 06-24-2016, 03:11 PM   #51
BandJCarm's Avatar
PS
I have one bar here so new posts take forever to load.
"Next to prayer, fishing is the most personal relationship of man"Calvin Coolidge
FROG AR-0019-242
BandJCarm is online now   Reply With Quote
Old 06-24-2016, 03:13 PM   #52
BandJCarm's Avatar
Oh and the bypass valve is closed....correctly
FROG AR-0019-242
Old 06-24-2016, 03:14 PM   #53
It looks like the valve right under the red box is the fresh water fill (just going by looking at the picture and could be wrong). Pull out the label maker and start marking things. You should be able to hear if the FWT is being filled if you turn the valve on.
2016 Flagstaff 23lb
Toddupton is online now   Reply With Quote
Old 06-24-2016, 03:15 PM   #54
wmtire's Avatar
Originally Posted by windsurfdog View Post
wmtire and 5picker...glad you agree with what I described in post 43. Indeed that is the cold water inlet valve to the water heater.
Sorry I didn't see your post, but yes, I do agree with your and 5pickers assessment....which it now appears solved the problem for the OP when he turned the valve correctly.
Thank You for your help in this matter, and again apologies for not acknowledging it before.
2011 Flagstaff 831 RLBSS
Hypochondria is the only illness I don't have.
Old 06-24-2016, 03:26 PM   #55
BandJCarm's Avatar
Guys I thank you!! I apologize but these posts are not showing up till later just now saw #43...or maybe I missed it.
Cannot understand this....but I believe it, obviously.
Still have those two questions though.
FROG AR-0019-242
Old 06-24-2016, 03:28 PM   #56
Glad we are making some progress.
I'm still not convinced we have you squared away as I also see a blue and red lever (left side of photo) that may have something to do with filling your fresh water tank.
Detailed close up photos of those might help us answer your questions about what valve fills your fresh tank.
Yes, the ice maker should work fine on using the fresh tank/pump and yes, you just leave the pump on. It is an 'on demand' system and will run the pump when needed.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 06-24-2016, 03:30 PM   #57
You were absolutely on the money dog!
Old 06-24-2016, 03:45 PM   #58
BandJCarm's Avatar
Those are ok pretty sure.
Two more pictures
ID:	112044   Click image for larger version
FROG AR-0019-242
Old 06-24-2016, 03:52 PM   #59
BandJCarm's Avatar
Ok. I'm going to go take a shower and report back if o have continuous hot water.
Also just found a big hole/crack in shower.
Geez
FROG AR-0019-242
Old 06-24-2016, 04:20 PM   #60
BandJCarm's Avatar
Won't stay lit. No hot water now.
Dsi/flt lights up after a while.
Thought maybe out of propane. Switched to new tank.
No change. Won't light and rarely when it does it won't stay lit.
FROG AR-0019-242
hot water, water
