Old 10-09-2017, 07:59 AM   #1
Hot water out of cold side
I have a new Sabre 30RLT and Im getting hot water out of every cold water valve in the camper. Its just for a short time then the water turns cold. You would think it would be the other way around.
Is this normal, something I should be worried about or just an aggravation?
Wheel is offline   Reply With Quote
Old 10-09-2017, 08:05 AM   #2
Capt. Mike's Avatar
Depending on where you are, and the ambient temperature outside, it is fairly normal. All of the water lines are Pex (plastic) and with warm air temperatures, it doesn't take too long for the water in those lines - and in your hose - to warm up. If you are getting cold water after a few minutes (either from your fresh-water tank or from a "city water" spigot), you are OK. Don't worry about it.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
It's not how old you are, it's how you are old.Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 10-09-2017, 08:15 AM   #3
Flybob's Avatar
Check you WH winterization valve see photo. The center valve in the photo should be perpendicular to the crossover piece. Also check the outside shower. The faucets can be on with the shower head stop engaged and you will not have water flow.
Name:	Hot water heater bypass good.jpg
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 10-09-2017, 08:22 AM   #4
Capt. Mike's Avatar
OP says he gets water flow, but that it is warm coming out of the cold faucets. But after a while it gets cold as it is supposed to be.
BTW, Bob, why are all of the valves in your picture open? If the w/h is in use, the by-pass should be closed. If winterized, the "cold in" and "hot out" valves should be closed. (Just bustin' your chops)
Mike and Yvonne
Old 10-09-2017, 08:33 AM   #5
Semperfi24's Avatar
If I were going to take a guess, because I have seen this, its simply the water source. I use a 25 foot hose from the water source to the city water inlet. I have been at campgrounds where all 25 feet of hose are in the sun, meaning the water in that hose is probably 100+ degrees before it enters the camper. So whether you turn on a cold water valve, or a hot water valve at your sink (or even flush the toilet), the first 20 seconds is going to "hot". Then it gets cold...
_________________________
2018 Rockwood Mini Lite 2504S
2018 Ford F150 Lariat Special Edition 3.5 Ecoboost
Semperfi24 is offline   Reply With Quote
Old 10-09-2017, 08:34 AM   #6
Flybob's Avatar
Only photo of WH on this machine. That's why I added note. OR maybe just wanted to show him how it would look if it was wrong.
TST Tire Monitors
2 100W solar panels
Old 10-09-2017, 08:53 AM   #7
fonzie's Avatar
X2
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 10-09-2017, 09:26 AM   #8
Capt. Mike's Avatar
Mike and Yvonne
Old 10-09-2017, 09:34 AM   #9
There was someone on the forum that had a similar issue. In his case, his outdoor shower was the culprit. He had both valves turned on to the shower head but had the shower head turned off so this resulted in flow from the hot to the cold side at the valve since they were both open.
Edit: I see FlyBob already mentioned this.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 10-09-2017, 12:37 PM   #10
Also if the bypass center valve is open with the upper and lower valve open you will get both temp. Of water. The center valve needs to be closed for the hot water to work
b1hasj83 is offline   Reply With Quote
hot water, water
