Old 03-28-2016, 09:17 PM   #1
hot water smells like petroleum gas
We just purchased a 2008 Forest River Berkshire 390BH and took it for the first trip last weekend. When we took a hot shower, there was a distinct petroleum gas smell coming from the water. It was not a rotten egg sulfur smell - it was definitely a petroleum type gas smell. It was only from the hot water when the hot water heater was on. The cold water did not smell and it did not taste bad. It is currently in the shop getting some minor repairs and they are stumped as to what it is. Does anyone have any ideas for us newbies??? Thanks!
pigletat100acres is offline   Reply With Quote
Old 03-28-2016, 09:23 PM   #2
Ddubya's Avatar
The sacrificial anode in the water heater needs replacing. Chemicals in the water will erode it and smell like rotten eggs.
Ddubya is offline   Reply With Quote
Old 03-28-2016, 09:23 PM   #3
Bluepill's Avatar
RV/Marine antifreeze does have an aromatic smell that some might describe as gasoline-like. I would flush a the whole system with a bleach disinfecting solution and see what happens.
Many youtube videos available. One is here: https://youtu.be/jEepug8N-aE
2008 Itasca Meridian 37H
Old 03-28-2016, 09:25 PM   #4
Ford Idaho's Avatar
Do you know if there was a problem removing the anode rod?
If there was do you know if the threads were recut and if there was some type of lube used at that time?
Old 03-28-2016, 09:31 PM   #5
Thanks for all of the quick replies! We have no idea about the anode rod. We will check out the you tube video about the antifreeze. Thanks again!
Old 03-28-2016, 10:00 PM   #6
dan-nickie's Avatar
Does the 2008 Berkshire have the on-demand water heater?
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 03-28-2016, 10:09 PM   #7
No we do not have the on-demand hot water heater - wish we did!
Old 03-29-2016, 12:16 PM   #8
hotrodj125's Avatar
If you have some "DEAD END" water lines in the coach, IE: washer/dryer hookup, you might still have winterizing pink juice in those lines causing it to smell.
Rod & Linda Johnson
Cedar, Minnesota
2006 F-250 SD 4x4 6.0
2012 Columbus 320RS
K-9's Lucy & Lizzie
Enjoying Life 1 Campground at a time
hotrodj125 is offline   Reply With Quote
Old 03-29-2016, 12:31 PM   #9
Kenny kustom's Avatar
Nice!
I never thought of those lines.
We have the plumbing, but no wd.
Best not to forget about those lines when comes time to winterize.
Good info!
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
gas, hot water, water
