Old 11-10-2014, 07:47 PM   #1
hot water supply
My son just retired from the army and he bought a Wildwood x-lite to live in until he gets his house built. Everything is fine except hot water supply. He has a few problems and he uses quite a bit of hot water to help him out. I have a small building set up with washer dryer and a propane hot water heater that I used on a camper I lived in until my house was built.
My question is- is there a water supply diagram available so I can see where to connect on this model or does someone who can tell me how/where to do it
Scott
scottavery11 is offline   Reply With Quote
Old 11-10-2014, 09:58 PM   #2
Dave_Monica's Avatar
I'm not sure what you plan to do. If you want to use the additional water heater in place of the one in the camper, you should be able to tie it in at the output of the campers' water heater and use the bypass valves to isolate the existing heater. The additional water heater would have it's own water supply, correct?
Dave
Old 11-10-2014, 10:03 PM   #3
heater byppass
Thank you, I'll look first thing in the morning
Scott
hot water, water
