Old 09-24-2011, 04:56 PM   #1
Brigitte
boubou's Avatar
Hot water tank
Irst time out camping in travel trailer ever. All went well, looks like we didn't forget anything. We have the hot water tank on electic and the tank was filled but we always seem to have air in the hot water tap with the water. Cold is fine.
What am I doing wrong?
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
boubou is offline   Reply With Quote
Old 09-24-2011, 05:02 PM   #2
backin15's Avatar
Congrasts on the new camper!
You just need to purge the air out. Leave the hot tap open for a few minutes until it stops spitting air.
backin15 is offline   Reply With Quote
Old 09-24-2011, 06:33 PM   #3
I have found the best way to get all of the air out of the water heater is to open the pop off valve & then turn the pump on until air stops coming out, then you can close the pop off valve. (you access this from the out side)
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
Old 09-24-2011, 07:15 PM   #4
jimh's Avatar
is it all ur faucets or just one?
my sink did that for 6 months. was also getting a few drops of water under the sink. finally determined the water was coming from a crack in the mixing area of the faucet (not from around the top of the faucet and going between the faucet and sink).
changed faucet, problem disappeared for a couple yrs. when it started sputtering again, it was also a crack in the mixing area of the new faucet.
i don't understand it, but it did happen.
none of the other faucets sputtered.
jimh is offline   Reply With Quote
Old 09-24-2011, 07:32 PM   #5
Brigitte
boubou's Avatar
Looks like i disn't wait long enough. Working fine now. Thanks
Superglide 2700
Timbrens
