Old 04-27-2011, 12:09 PM   #1
Hot water tank drain plug
Discovered that the hot water drain plug in my new tt has been leaking. Does anyone use teflon tape on their plastic caps, for example: low point drains and/or other plastic to plastic or plastic to metal fittings? I am hoping to apply a little tape and have problem fixed, what do you think?
2011 Coachmen 292 bhds
2005 Silverado 5.3 L w/ 4:10 and Equal-i-zer
Eric, Heather and Elaine Higgs
TopGobbler is offline   Reply With Quote
Old 04-27-2011, 12:20 PM   #2
Big Dawg's Avatar
I have used the teflon tape before. There has not been a problem.
2004 Chevy Avalanche Z66 W/Transmission Cooler
2011 Grey Wolf 28BH
Blue Ox Sway Pro WDH
2 Beagles (Snoopy & Dexter)
Big Dawg is offline   Reply With Quote
Old 04-27-2011, 12:41 PM   #3
KyDan's Avatar
Your hot water heater drain is not plastic is it???
Yes you can/should use teflon tape on plastic or steel
My drain tends to rust the threads so I use Oatey "great white"
pipe dope with teflon. You can get that in a small can
at Home Depot or Lowes home centers.
Try the teflon tape first.
Dan & Rita D
2004 5.3L Silverado 1500 ext. cab 2WD
Blue Ox WD hitch, AirLift load levelers
2013-41, 2014-31, 2015-40, 2016-38
Old 04-27-2011, 03:25 PM   #4
grhodes50's Avatar
My Atwood water heater has a plastic drain plug. It's not showing any signs of leaking, but I would try the teflon tape if it does happen to in the future.
Gary & Trish
2016 Nights Camped - 9
grhodes50 is online now   Reply With Quote
Old 04-27-2011, 03:39 PM   #5
I just replaced my anode rod on my suburban and put the oatey paste on it so far so good
Santaclause is online now   Reply With Quote
Old 04-27-2011, 03:40 PM   #6
BOBFIDY's Avatar
After getting mine out of storage a couple weeks ago we used teflon tape on the water heater drain and the water line drains...No issues at all.
2010 Salem LA 292FKDS
One of the Original 14 F.R.O.G.s
1st, 2nd, and 3rd INTERNATIONAL F.R.O.G. RALLY Branson. MO.
1st, 2nd, and 4th INTERNATIONAL RALLY Goshen, IN.
BOBFIDY is offline   Reply With Quote
Old 04-28-2011, 07:42 PM   #7
Teflon tape is the perfect quick sealant. Make sure that you buy the pink teflon tape. It is a bit more expensive than the white but perform much better than the white.
capucine is offline   Reply With Quote
