Old 01-22-2014, 07:24 AM   #1
thegreatoutdoors's Avatar
Hot water tank drain valve.
Hey everyone, we are new to the camping world and I was wondering if there was away to install a drain valve(petcock or small ball valve) on my hot water tank drain. Maybe I'm not looking at it from the proper stand point, but wouldn't the issue be the anode? Thanks for any input and suggestions.
thegreatoutdoors is offline   Reply With Quote
Old 01-22-2014, 07:36 AM   #2
Here ya go:
http://www.campingworld.com/shopping...rs-4-12-/37395
Just don't forget you'll still have to remove it to check the condition of the sacrificial anode rod. Best to do this at the end of the season when you flush out and crud from the tank.
Old 01-22-2014, 07:37 AM   #3
Old Enough to Know Better
gasman6674's Avatar
I believe one of the vendors (camco, atwood) have an anode with a drain built in. I remember seeing it I think at CW (but I also suffer from CRS)
Regards and welcome to the fourm
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 01-22-2014, 07:39 AM   #4
Todouble's Avatar
Thought of this many times on my old TT. I don't know how you would keep the anode rod in service and add a drain. I always just pulled the rod when I needed to drain. Although the new fiver I bought has no anode rod and just a plastic plug. Now that I may be able to add a drain. Not sure why there getting away from anodes. Dealer did tell me that most people wanna change out the plastic plug for a brass one but not to because it's designed to blow out if there's a prob. Although I thought that was what the pressure/temp relief was for. Redundancy??
Todouble is offline   Reply With Quote
Old 01-22-2014, 07:43 AM   #5
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
Wouldn't using an anode with drain lead to corrosion of the device into the tank unless owners make sure they remove it annually?
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 01-22-2014, 07:54 AM   #6
I was thinking the same thing Todouble, I'm not sure if this is even feasible. Just something my brain was thinking about trying to make life easier.
2014 Salem 26TBUD
2014 Ford F-250 SuperCrew 4x4
2001 F150 SuperCrew(Retired from service)
Old 01-22-2014, 07:58 AM   #7
Thanks for the link Wiscampsin, I have access to all the necessary pipe and fixtures that would be involved to make this work. But my issue is "what about the anode?" How will it allow water to drain when it is installed? This all my be just a "pipe" dream.
2014 Salem 26TBUD
Old 01-22-2014, 08:03 AM   #8
gasman6674,I sometimes suffer from (trying to better someone else's product) for no apparent reason. If you could find such an animal like your talking about, please send me the link.
2014 Salem 26TBUD
Old 01-22-2014, 08:13 AM   #9
gasman6674's Avatar
The greatoutdoors the link Wiscampsin posted is what I was talking about (he beat me to it:-), It is an anode with the drain built in easy peezy. The Atwood heaters with the plastic plug only are a aluminmum tank and dont require an anode, but there has been lots of discussion on here about adding one
Old 01-22-2014, 08:31 AM   #10
Todouble's Avatar
Did not know they were aluminum vs my old TT with a anode which I'm guessing was steel.
drain, hot water, tank, water, water tank
