Hot Water Tank leaking
If it is the pressure relief valve, Turn off the electricity/ Gas to the HWT. Turn
off the water supply to the camper. Open a sink hot water faucet to bleed pressure down the tank. Now, but be careful open the pressure relief valve to bleed off the pressure in the HWT. You have to put air pocket back into the top of the tank to stop the pressure relief valve from leaking. Once this is done, turn everything back on . This should correct the pressure relief leak.
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2023 69 DAYS
[SIGPIC][/SI[SIGPIC]
