Old 06-29-2017, 10:41 AM   #1
Hot Water Tank LP Fitting Size
Hi everybody! First time poster here, hope you can help me. I have a 2013 Coachmen 320BHDS. Due to a negligent winterizing in the fall I had to replace my hot water heater. Finished it up last night only to discover I somehow pinched the propane hose and cause a pinhole . I need to know if the fittings are 1/4 NPT or 3/8 NPT. The hose runs from the manifold behind the right rear tire to the regulator on the unit. Thank you in advance!
Jay
Jaybaar is offline   Reply With Quote
hot water, tank, water, water tank
