Old 02-26-2014, 04:24 PM   #1
jlgail4309's Avatar
Hot water tank on with No Water
Camped last weekend drained the water before leaving camp. Drove a 1.5 hours before finding the water tank still on with no water. Gas was on to head in the _____!!!
So what problems should I look forward too.
2008 Jeep Grand Cherokee Diesel
2013 Salem Cruise light 19bh
Hensley Cub hitch ,
jlgail4309 is offline   Reply With Quote
Old 02-26-2014, 04:38 PM   #2
Kaadk's Avatar
On gas power or on electric power?
If electric, the elements are fried and will need to be replaced.
If gas. I don't know.....
There's no use crying over spilt milk, unless it's on your keyboard.
Old 02-26-2014, 04:40 PM   #3
BigTJohn's Avatar
Hopefully nothing too major. Hope you did not use electric before filling with water. Also hope you let it cool before filling with water. The heater (gas) would have heated the empty air space, sensed it was hot and shut off. As air is sort of an insulator, it may not have cycled very much during the 1.5 hrs. You "should" be OK.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 02-26-2014, 04:47 PM   #4
heater
Most fires are caused while driving with propane on. fill er up ; fire er up and see what you have.
Vacationman is offline   Reply With Quote
Old 02-26-2014, 05:11 PM   #5
Todouble's Avatar
Elec you just toasted your element
Gas- nothing you will be fine!
Todouble is offline   Reply With Quote
Old 02-26-2014, 06:21 PM   #6
Evereddie's Avatar
If you drained the water while in camp and the power was on , ya the element is toast. If only the gas was found on while on the road, not big problem. Remember, there is no electricity while on the road.
Evereddie is offline   Reply With Quote
Old 02-26-2014, 06:50 PM   #7
jlgail4309's Avatar
Yes electric and gas was on going to order some parts . Thanks everyone!!!
Hensley Cub hitch ,
Old 02-26-2014, 10:55 PM   #8
Moderators' Assistant
bikendan's Avatar
we have a check list for leaving posted next to the radio in our Roo.
covers everything including the electric WH switch and the red toggle for the propane side of the WH.
never leave a campground without going through the list.
Dan-Retired Firefighter/EMT
2016 PrimeTime TracerAIR 255, pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 02-27-2014, 03:43 PM   #9
To late this time but if you only turn the electric on the water heater 30 minutes before you need hot water and then turn it off when you are through using hot water that wouldn't ever happen. That is what we do and if I didn't I would forget and leave it on. Good Luck
whj77372 is offline   Reply With Quote
Old 02-28-2014, 07:52 PM   #10
jlgail4309's Avatar
Check list great idea !! First trailer learning the hard way!!
Hensley Cub hitch ,
hot water, tank, water, water tank
