Old 07-28-2014, 06:34 AM   #11
TURBS's Avatar
Originally Posted by OldCoot View Post
Would venture to guess the switch is wired correctly, but is stuck in the ON position.
I concur.
"sabre owners united!"
turbs
Old 07-28-2014, 06:49 AM   #12
dcheatwood's Avatar
But he said he's turned it off at the breaker also. ???
2018 Forester 3011 DS
Old 07-28-2014, 06:58 AM   #13
Originally Posted by CableXJ View Post
I have a Surveyor Eco-Lite (2011) and the hot water tank is always hot. I have made sure the switch at the kitchen sink is OFF as is the black switch outside beside the tank. I have even switched off the breaker that is labelled H/W and both propane tanks are shut off. So why is the hot water tank still hot?
Thanks in advance.
Sounds like you need a meter to check this W/H system. Looks like you have more than (1) thing wrong at the same time! Youroo!!
Old 07-28-2014, 07:02 AM   #14
KyDan's Avatar
Miss labeled breaker IMO.
Cable- you should be able to access the rear of your hot water heater
inside the trailer or in a storage area.
You will probably find the water heater is plugged into an outlet.
Unplug the water heater and plug in a light. Go to your electrical panel
and shut off breakers one at a time until the light goes off.
THAT is the water heater circuit breaker!
The outside switch as shown in the photo in post 6 is prone to sticking.
Mine is stuck on right now but my circuit breakers are labeled correctly
and I just use the circuit breaker to shut off the electric water heating
element when I don't want it on.
Good Luck!
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
KyDan is online now   Reply With Quote
Old 07-28-2014, 08:13 AM   #15
Thanks guys. The switch was mislabeled. Water tank has cooled off now.
CableXJ is offline   Reply With Quote
Old 07-28-2014, 08:15 AM   #16
dcheatwood's Avatar
Got er done.
Old 07-28-2014, 08:38 AM   #17
wmtire's Avatar
Are you referring to the black switch on the tank being miswired, or the circuit breaker being mislabeled?
As Youroo stated, you may have more than one problem, since the circuit breaker should have killed power to the electric heating element irregardless of the black switch position.
If the circuit breaker was mislabeled (thus the correct one never actually turned off), then the black switch should have turned off the electric heating element, which sounds like it didn't.
2011 Flagstaff 831 RLBSS
Never Apologize! Never Explain!
Sorry, thatís my motto.
Old 07-28-2014, 08:52 AM   #18
dcheatwood's Avatar
Agreed. When all else failed, the switch on the WH should have killed it. I'm thinking the tank switch was miswired and he thought it was off when on.
Old 07-28-2014, 09:11 AM   #19
Don't know how you can miswire a simple on off switch. Only 2 terminals.
Old 07-28-2014, 09:32 AM   #20
Hey OC, have you ever seen a (Amish) electrician? Youroo!!
hot water, tank, water, water tank
