Old 06-27-2016, 09:02 AM   #11
A fried element will cause an open circuit and cannot trip a breaker.
Old 06-27-2016, 09:36 AM   #12
Georgia Frog Rally 2018
aceinspp's Avatar
When I had one get fried it keep tripping circuit breaker. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 06-27-2016, 09:37 AM   #13
Pickin' & Campin'
Originally Posted by wmtire View Post
Neil, it really depends on how the element opens up, if it's touching the side of the tank, how much the water conducts electricity, etc....as to if it trips the circuit breaker (which it definitely can)
Correct.
I've seen several elements melt over its self where they were a dead short and tripped the breaker.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 06-27-2016, 09:45 AM   #14
Would check the wiring to the element before putting a new one in. Most burned out elements will open the circuit. The OP's fried element will show if it shorted against the tank which would be an extremely rare occurrence.
Old 06-27-2016, 09:49 AM   #15
bubbles's Avatar
I was just pointing out that if the element is causing the CB to pop then it will ohm out shorted instead of an open as suggested by my referenced quote. The element is installed with a gasket and may not show a short to the tank itself if the electrical connections are isolated within the element. However; the element evendently can short across the hi and low connections when it blows and that is why the connections should be removed when checking it.
Old 06-27-2016, 10:06 AM   #16
The OP did not say the breaker would not stay on but said 'it happened again'. I assumed he meant he reset the breaker and after some time it tripped again.
I don't know about the elements in RV tanks but I know for home water heaters you can buy different wattage elements. Is it possible the OP bought an element that was too high in wattage?
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
breaker, hot water, tank, water, water tank
