Old 05-26-2013, 07:31 AM   #1
Bluegrass Family
Hot water TOO HOT~~ouch!
Motor Home, Georgetown 2012 (bought new in Dec 2011)
Hot water is way TOO HOT when using electric--literally burns your skin. We usually use gas when dry camping and both on shore power and turn both off when sleeping. Recently on shore power we forgot to turn off the electric and the next morning the pressure valve popped off and water was running down the side of our motor home.
Got any ideas or helpful suggestions? I'm pretty handy at fixing things.
Thanks for any help.
Doug
2012Georgetown is offline   Reply With Quote
Old 05-26-2013, 07:48 AM   #2
Herk7769's Avatar
Sounds like your AC thermostat is malfunctioning. It should shut off via the high limit bellows and turn on via the low limit bellows.
I think your high limit bellows has a hole in it and is not opening to remove power from the heating element.
Assuming your water heater is a Suburban:
Replace the one you have with: Suburban Water Heater 130 Degree Eco Thermostat 232306 | eBay
It is an easy repair (one nut and two wires); just make sure to open the AC breaker in the power panel.
Name:	AC diagram.jpg
ID:	31381   Click image for larger version
ID:	31382   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 05-26-2013, 08:00 AM   #3
Bluegrass Family
Wow, thanks for answering so quickly and with such detailed info!
Got any ideas of what would make the thermostat go bad?
Old 05-26-2013, 08:54 AM   #4
Herk7769's Avatar
Doesn't really matter. Sometimes things just break.
My guess is you will find out (please take a photo) when you remove the rubber reset button cover.
Old 05-26-2013, 08:59 AM   #5
Engineer of Crazy Train
ChooChooMan74's Avatar
Sometimes, you post a question at just the right time!!!
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 05-26-2013, 09:03 AM   #6
Herk7769's Avatar
and that I know the answer to!
Old 05-26-2013, 09:20 AM   #7
Just turn the cold water on with the hot, takes less hot water. Doesn't do anything about the popoff
Old 05-26-2013, 09:32 AM   #8
Poppy94's Avatar
I gotta know, are you the resident comedian or is your real name Mr. Obvious?
Poppy94 is offline   Reply With Quote
