Old 08-31-2015, 03:12 PM   #1
How do you winterize black tank flush???
I think that I've finally got this somewhat figured out, but now I'm wondering
how you winterize it. Since it is separate from the main plumbing system, I believe?
Salem Lite Hemisphere 232IS
Ford F-250 Super Duty Lariat Crew Cab v-10
jas451 is offline   Reply With Quote
Old 08-31-2015, 03:17 PM   #2
TURBS's Avatar
I've never winterized mine.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 08-31-2015, 03:19 PM   #3
Ive never winterized mine either. I guess if you were worried about it, you could blow air through it maybe?
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2018-16) (2017-16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 08-31-2015, 03:24 PM   #4
grumpy0374's Avatar
Just before I winterize my Lexi's lines, I pour 2 gallons of rv anti-freeze in both the black tank and gray tank. Maybe overkill, and not needed, but the stuff is cheap enough, and I don't worry about any water left in the tanks freezing.
Grumpy
grumpy0374 is offline   Reply With Quote
Old 08-31-2015, 03:29 PM   #5
Alleged curmudgeon
Vern's Avatar
Not generally considered a big issue, but the presence of any water in the tank seems to risk some freezing around the valve seal. Therefore, I always try drain it well at my last dump of the season, and again at winterizing time. If you use RV antifreeze, you will be adding a little of the pink stuff to it when you flush the toilet to winterize the supply lines to the toilet. I try to run the flush until there is about as much pink stuff down the drain as there was water before it. That should technically do the job.
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34); 2018 (39); 2019 (22)
Vern is offline   Reply With Quote
Old 08-31-2015, 03:30 PM   #6
Alleged curmudgeon
Vern's Avatar
I agree with grumpy...
Grumpy
Seems like a cheap piece of mind.
Lee
Old 08-31-2015, 03:30 PM   #7
mud yapster's Avatar
Never have winterized my black or grey tanks. I drain them that's it. I blow air thru my water lines and fixtures and drain water tank. Never had an issue. Takes 1 beer to winterize my RV if DW helps by opening and closing water faucets. Our 5er doesn't have pee traps so I don't pour RV antifreeze down the drains.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 08-31-2015, 04:02 PM   #8
I blow out the black tank flush when I blow out the rest of the plumbing lines.
Old 08-31-2015, 04:18 PM   #9
mark0224's Avatar
I use an air compressor to blow all the regular water lines then add antifreeze to them and run the antifreeze until some goes down the drains. I always dump some extra down the drains after, enough to push all the water out of the traps then open all the black and gray tanks to get any liquids left in the tanks out. Never had a problem in 17 yrs.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 09-01-2015, 11:45 AM   #10
waiter21's Avatar
When I drain mine for the last time of the year, I leave the drains open. I then dump a quart of antifreeze in each of the "P" traps. (sinks, shower, toilet)
The water will drain out of the traps and out the black and gray tank drains. Any residual water in the tanks and drains should now be diluted with antifreeze.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
black, black tank, black tank flush, tank, winter, winterize
