Old 04-12-2016, 11:23 AM   #1
mrpep's Avatar
How I finally turned on my water heater pilot.
So I bought an older 1998 forest river wildwood 24fb for a low price, I think. I began to look over things, electrical, plumbing, etc etc . but was stuck on the water heater, I could not light the burner. I had such a difficult time that when I finally turned it on it was suggested I post so I can help others and so I shall. The instructions and videos stated to turn the pilot dial from off to pilot, press down on pilot and light, once lit I had to release the pilot and turn knob to on. I did this numerous times and no luck. I ended up taking most of the heater apart and cleaning it all out and putting it all back together. I then let the pilot light burn for an hour and still nothing , I finally walked over and wiggled the knob while on the pilot position and for some reason pressed it down. Once I pressed the on knob down the burner ignited , such a simple detail that was missing from the manual and videos, lol. I will post pics of the unit and a few of my old trailer that I really like a lot. Good luck if you're having issues and just research, ask questions and five in there and chances are you'll figure it out.
mrpep is offline   Reply With Quote
Old 04-12-2016, 11:25 AM   #2
mrpep's Avatar
Hope I can help someone out ..
Old 04-12-2016, 03:24 PM   #3
SkyWatcher's Avatar
EXCELLENT! Glad you got to the bottom of that!
'16 Rockwood Minilite 2109S
'16 Silverado 2500 4X4 6.0L/4.10
'09 Keystone Passport 285RL -traded in
'95 Coleman popup - sold it after serving us well
SERENITY NOW!
SkyWatcher is offline   Reply With Quote
Old 04-12-2016, 03:56 PM   #4
TURBS's Avatar
Probably helpful to anyone owning a 16 year old trailer
Most everything after 2000 has dsi .
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "0"
2015 nights camped "34"
Old 04-13-2016, 01:25 PM   #5
I am having the exact same problem with my 2011 unit. I will try and see if I am successful. Thanks
trailerdog is offline   Reply With Quote
Old 04-13-2016, 01:26 PM   #6
mrpep's Avatar
When you turn to on, press down , somehow that was what I was missing
Old 04-13-2016, 02:08 PM   #7
When you hold down the pilot/burner knob you are heating the thermocoupler, what happens is a thin wire expands and opens the gas valve at the burner. What happens is sometimes there is a kink in in this thermocoupler or it is bad. You can take a piece of sandpaper and clean this it might start working. You can check it by removing it from gas burner take a lighter and heat the tip if the wire doesn't move it's bad and has to be replaced. First thing make sure there is no obstacles in gas tube (mud dauber, spider webs, etc)
Myrle is offline   Reply With Quote
Old 04-13-2016, 04:17 PM   #8
CDR USN Ret
Originally Posted by Myrle View Post
When you hold down the pilot/burner knob you are heating the thermocoupler, what happens is a thin wire expands and opens the gas valve at the burner. ...
Nope. The thermocouple, when heated, generates a small (about 25 millivolts) DIRECT CURRENT voltage. This voltage (think small battery) drives a circuit running through a pilot solenoid coil in/on the gas valve. The current running through this pilot coil produces a magnetic field - that magnetic field holds open a small valve that provides gas to the pilot burner.
If the pilot light, for any reason, goes out - the thermocouple cools, the current drops, the pilot valve closes, and gas stops flowing to the pilot burner.
The reason you have to hold the button down when lighting the pilot, is to mechanically open the pilot gas valve. You then have to keep pushing down until the thermocouple has a chance to reach a high enough temperature, to develope enough current flow, to allow the pilot solenoid's magnetic field to do the holding.
Generally, the problems with standing pilots are:
1) No gas to valve. Disconnect the pilot gas tube at the gas valve and depress the button. If gas is present at the gas valve and not at the pilot, check the pilot tube and pilot assembly orifice for blockages; clean or replace as necessary
2) a blocked pilot orifice. The pilot orifice is at the end of the small gas line going to the pilot. The come in different configurations, but all have a very small hole through which gas is metered at the pilot burner. For some reason, it seems small spiders love to spin webs here. Although reaming is not recommended due to the possiblity of damage to or changing the size of the orifice, I have had great luck using small, thin plastic (like a bristle from a fine hair brush), to reopen this orifice.
3) corroded or misaligned thermocouple (polish the surface a bit with some very fine sand cloth, and with the pilot flame ignited, about 3/8 to 1/2 inch of the thermocouple tip is actually enveloped by the pilot flame. You can make mechanical adjustments to its positioning by moving the thermocouple back and forth in its mount or side to side by slightly bending it bracket.
4) corroded or oxidized connection of the thermocouple line connection at the gas valve. You can unscrew the "tube" going from the thermocouple to the valve (it's an electric connection - not gas). You will see a small "tab or hat" at the end of the inner part of this tube. if you look closely, you will see an insulating washer that keeps it from contacting the outer part of the thermocouple tubing. Polish this tab with the with same sand cloth you used for the thermocouple.
By the way - you can check to see if the thermocouple is generating enough voltage by manually lighting the pilot (remember - hold the gas button down!), let the thermocouple get hot, then measure VOLTAGE between the tab and the outer part of the thermocouple tube. If there's at least 20 to 30 mV DC present, the thermocouple is operating satisfactorily.
4) a bad pilot valve solenoid. The button end of the thermocouple is screwed into the top of a device that looks like a small can with a plunger coming out its end. There is a gasket on the end of this plunger, and a spring that keeps the plunger extended. You can remove this component from the main valve by unscrewing it. (remove the thermocouple line first - and turn the gas off because this device DOES provide a gas seal). If you passed the check in (4) above, you can test this "can". It involves removing the thermocouple from the pilot burner, and the solenoid from the main valve, screwing the thermocouple tubing back into the solenoid, taking the assembly to your gas stove and holding the thermocouple in the stove burner. Once the thermocouple is hot, you should see the plunger has pulled in. If it did not, the solenoid can be replaced as a separate part. (a trip to a small appliance parts shop).
There are, of course other things that can go bad, but probably 90% of the time those above are the standing pilot faults.
2015 XLR415AMP
2011 3500HD Duramax/Allison/90 Gal Aux
2015 HD Limited Low
DSQR is offline   Reply With Quote
heater, water, water heater
