Old 05-29-2013, 03:12 PM   #1
How long should it take to dump holding tanks?
Newbies to a travel trailer here. Just came back from our first trip out and had a great time. However, it seemed to take FOREVER to empty our holding tanks. On average how long should it take? Our grey tank seemed to take much longer almost just a trickle.
Advice? Possible issues??
Thanks in advance for your experience and help.
jarvo9 is offline   Reply With Quote
Old 05-29-2013, 03:13 PM   #2
Himcules's Avatar
got one of those clear plastic adapters so you can see the flow? it should flow pretty good... full tanks will take several minutes to empty...
himcules (10x stronger than hercules)
2013 Forest River Berkshire 390BH-60
ex 2007 Jayco Greyhawk 31SS
Himcules is offline   Reply With Quote
Old 05-29-2013, 03:20 PM   #3
Herk7769's Avatar
It takes a while to dump 40 some gallons through a 3 inch opening.
In case you have a TurboFlush, plan on running that for at least 10 minutes and ideally 15-20 or until clear. Obviously if there is a line for the dump station, you might want to wait for a full hookup campground for a serious flushing.
Keeping the tanks as squeaky clean as possible with frequent and thorough flushing and coated with a "slickener," like Calgon Liquid Water Softener, will speed up the process some.
HAM CALLSIGN - KC3FFW
Old 05-29-2013, 03:22 PM   #4
Anacortesians
Our motor-home's tanks (60 gallons each) dump from full in about 3 minutes for each one. I have a clear-plastic 90-degree elbow with the lugs to match the drain and the sewer hose so I can watch the flow. If we're at the full stretch of our sewer hose, it might take and additional minute.
It sure isn't a "trickle" - more like a fire hose. At the end of the grey tank dump, the flow rate slows down, then there's a big rush dumping the last two gallons or so.
Frank and Eileen
No longer RVers or FR owners
Old 05-29-2013, 03:25 PM   #5
You give NO info on type of RV,# of tanks,how many dump outlets on unit,how many Gal.tanks are? Need info! Ps,how long will it take to get to my Campground? Youroo!!
Old 05-29-2013, 03:27 PM   #6
Rebel702's Avatar
Make sure your rig is tilted to the dump side so gravity can help. Also, dump full tanks. If not full, just add more water before opening your valve(s).
Rockwood Windjammer 3002W (11/10/2011)
2011 Sierra Denali HD - Duramax/Allison
EQ-4, 14,000/1,400
2006 Yukon Denali
Rebel702 is offline   Reply With Quote
Old 05-29-2013, 03:38 PM   #7
jlbreaux's Avatar
Depending on how many gallons you have. should not take longer than 10 minutes. rule of thumb, ALLWAYS dump black water first then dump grey/galley water. Helps to clean the poop chute (drain pipe).
2011 Puma Unleashed 365 QLB
2006 GMC HD Sierra SLT quad cab 4x4 6.6L LBZ Allison tranny
2008 Arctic Cat Prowler 650 H1
2006 Polaris H.O. 500EFI Sportsman
1996 Harley Davidson Heritage Softail
jlbreaux is offline   Reply With Quote
Old 05-29-2013, 04:12 PM   #8
Rebel702's Avatar
It would help to provide your RV information - make, model. There could be debris in the grey tank. May help to post pic of your dump valves if they are plumbed into a central main valve. Could be a valve stuck.
How close is your dealer, let them check it out?
EQ-4, 14,000/1,400
2006 Yukon Denali
Old 05-29-2013, 04:29 PM   #9
sequoiaguy21's Avatar
I agree with himcules on the clear adapter to see what's going on. I believe my tank drains considerably slower when there are 2 or more RV'ers behind me at the dump station waiting for me..
2013 Salem 26TBUD
2010 Sequoia, P3, Equal-i-zer
2 Kids
sequoiaguy21 is offline   Reply With Quote
Old 05-29-2013, 04:59 PM   #10
Thanks tor the replies. We have a brand new Wildwood 195BH with 25 gallon tanks. Seperate black and grey tanks. Draining is definitely NOT anything like a firehouse and takes much more than 5-10 minutes. We do have the clear adapter that is how we knew it was just a trickle for the most part.
