Old 02-28-2016, 10:50 AM   #61
Phat Phrog Stunt Crew
elind's Avatar
Do a test of your hot water system. Take a 5 gallon bucket into the shower and run the hot water shower in it. Will the hot water get cool before the bucket is full? Or dump the bucket to see if you can get the second bucket full of hot water. This will tell you how much usable hot water you have. While doing this check the time the hot water did last.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 02-28-2016, 05:00 PM   #62
Rupkin2's Avatar
I think this might be a bit deceptive, reason I say that is how open is the valve? A fully open valve will get cooler water quicker than a mid/partially open valve.
Best way maybe to get a stop watch and have a real shower with the flow rate you like and time this from start to water cooling. Still won't be totally accurate but it will give you a good idea.
John
07- Classic 2500 LT CC 4x4 SB Duramax/Ally
13-320RLT Crusader TE
Reese 16K Kwik Slide/Prodigy brake contoller
Rupkin2 is offline   Reply With Quote
hot water, water
