Old 10-13-2016, 10:42 PM   #1
How to add to fresh water tank
I want to sanitize my fresh water tank bug how do i add my water and bleach solution into the tank?
pavetim is offline   Reply With Quote
Old 10-13-2016, 10:47 PM   #2
sgtlm17's Avatar
Do you have a gravity fill for your fresh water fill?
2016 Forester GTS 2801QSF
sgtlm17 is offline   Reply With Quote
Old 10-13-2016, 10:50 PM   #3
Iggy's Avatar
Don't know what type of rig you have but if you hook up a hose to fill the tank just pour a cup of bleach into the hose while attached to the rig then hook up to the hose bib and turn the park water on and fill your tank.
You have to fill the whole tank up so the bleach does its job and drain the next day and flush again with water to try and get the smell out.
That's it.
2012 Georgetown XL - 378TS
Old 10-14-2016, 07:40 AM   #4
jeff
jeff64's Avatar
How about a plastic funnel with a long tube for transmission fluid from your local auto parts store?
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 10-14-2016, 09:47 AM   #5
2014 cedar creek 36ckts. Good idea about putting it in the hose, not sure if i have gravity fill port
Old 10-14-2016, 02:56 PM   #6
Cjmurp's Avatar
Agree pour bleach into hose then connect to the fresh hookup. Funnel can be used to pour into the hose end. 1/4 cup per 15 gallons
Cjmurp is offline   Reply With Quote
Old 10-14-2016, 10:57 PM   #7
I have a cheap plastic flower water can that I pre-mix the bleach with water. I cut the bulb spout off so it is easier to pour into the fresh water tank.
Skyliner is online now   Reply With Quote
Old 10-14-2016, 11:35 PM   #8
Good Idea!!!
Freedom Express 246RKS
Ram Longhorn 5.7 L/1500 4x4
Unwind2 is offline   Reply With Quote
Old 10-15-2016, 09:07 AM   #9
cholrine fill.
I use a short length of fresh water hose about 3 feet long with garden hose shut-offs at both ends. I attach the closed male end to the fresh water fill inlet. I hold up the female end and fill the hose with chlorine and close the shutoff. I connect the female end to my fresh water hose that is connected to my house outside hose bib and turn the water on at the house. Open the garden hose shutoffs and the chlorine will go into the fresh water tank under pressure. Repeat if needed depending on the size of your fw tank. The garden hose shotoffs help with spilling to keep the chlorine in the short hose until you connect to your house.
markb422 is offline   Reply With Quote
Old 10-15-2016, 10:06 AM   #10
Wolverine 1945's Avatar
Does any one know how much bleach is it safe to use per gallon in fresh water tank,,, instead of using TastePure ???
Wolverine 1945 is offline   Reply With Quote
fresh water, tank, water, water tank
