Our fresh water fill is high in the inside of a "covienience" docking station, making it difficult to fill using a funnel.
so...
One of the first mods that I plan to do when our unit arrives is to add a second Winterizeing type valve on the high(er) presure side of the demand pump to direct the flow of water back into the tank.
Once that is done, whenever I need to tranfer water, I will run a hose between the winterizing inlet port and what ever I use to carry water in (probably 6 gal water jugs). With a couple of valve turns, the water should flow nicely from the jugs into the fresh water tank using the onboard demand pump. At least according to theory.
Cathy & Jeff
Midland, Michigan
2020 Cedar Creek 34IK / 2019 Ram3500 CID
